Hi all,
Quick question--
When my 02 Elantra accelerates, I hear a sort of high-pitched squealing noise coming from the engine for a little bit...then after a few seconds it stops. It's almost as if a belt is loose or something.
Is that what it is, a loose belt? If so, what belt is it? We just brought the car into the mechanic to check the timing belt, and he said it looked fine. I did a google search on this problem, and someone with a similar problem with a VW was told that it was a loose fan belt. But does an Elantra have fan belts? The only belt I see mentioned with Elantras is a "serpentine belt", which I'm not quite sure what that is.....
lol as you can see I know practically nothing about cars. Does anyone have any suggestions about this problem?
Thanks :) Dave
