QUOTE (mickey taker @ Nov 21 2008, 02:46 AM)
took the car to my local hyundai dealer yesterday afternoon they sorted out my airbag light ( there was a high resistance in the passenger side circuit causing it to come on ) and read then reset my codes ,
they said the error code was a historic one and hopefully they had sorted it out ,
four hours later the light was back on.
I found these two guides to sensor replacement for the v6 sonata and wondered if it was the same process for the trajet
first one
At home I don't have access to part numbers. The sensor itself is kind of a pain to replace. It is under the shift cable and has a 3 pin wire connector that can easily be broken if man handled. To replace remove the 2 12 mm bolts that hold the shift cable to the trans case and push the cable away from the sensor. DON"T try to un plug the sensor yet!!!! Remove the 10mm bolt that attaches the sensor to the trans case. Twist and pull the old sensor from the case. Now push the release tab on the connector and disconnect the old sensor. If the sensor won't un plug a hair dryer will warm up the plastic and help release the connector. Installation is the reverse of the romoval. You may also want to disconnect the negative battery cable during this repair. This will prevent the posibilitys of shorting out wires, clear any trouble codes and allow your trans computer to "Re learn" how to shift with a new and operating sensor.
Mac
and secondly more step by step
The input speed sensor is located on top of the transmission,
underneath the bracket attaching the shift cable to the transmission.
To replace:
1. Loosen the air intake hose clamp at the throttle body (may require
removing engine cover).
2. Unplug the air flow sensor connector.
3. Remove the three 10mm bolts holding the air box in place. One
will be under the fuse box. If you don’t have a long extension and
10mm swivel socket, you’ll need to remove the battery.
4. Remove the air box.
5. Remove the two 12mm bolts holding the shift cable bracket.
6. Clean the area around the speed sensor.
7. Remove the 10mm bolt and remove the sensor from the hole.
8. Unplug the sensor from the wiring harness.
9. Make sure the hole is clear and install the new speed sensor and
the 10mm bolt.
10. Attach the electrical connector.
11. Reattach the shift cable bracket.
12. Reinstall the air box.
13. Plug in the air flow sensor.
hopefully its a similar / same process for the trajet
Hi All
I do not understand why the gussing is for . all the required information is
available in the workshope manual and ready for downloading . check the
opening page of the forum it is pined there .
changing the input, output sensors is very easy, A/T fluid temp. is a bit diffecult , because you
have to open the fluid case to get there , resistance for sensor at 25c is at the manual .
regards
