Do you feel any loss of power during the "sputtering" ? Anything? If not, probably is something with your exhaust system, check for corrosion or a hit throuout the exhaust pipes. If I remember correctly, the exhaust system runs somehow on the right side of the car (I believe) and I would suggest checking everything from the manifold / header to the Cat converter to the Silencer (resonator) to the Muffler.
Also, check the hoses, when you accelerate the radiator fluids flow faster and with more pressure, a bad hose could be making the noise. Check the Raidator cap and have the Radiator checked for any possible leak.
However, if you feel power loss, might be a bad sparkplug or cable.
Good luck.
This post has been edited by EF/ELP: Sep 13 2008, 04:54 PM
