Hi,
Just cleaned the inside of the 'black box' with a 25 cm long hose (for watering the garden) attached with sticky tape to vacuum cleaner hose. I also cleaned with tyre-check pistol (mine has 20 cm hose). In the end I've used air conditioner cleaner spray for moth removal. Filter has fitted perfectly - it comes in 2 parts, each has dimensions around 10cmX20cmX1cm. Haven't noticed any difference in air flow before and now with filter.
Yep, it true that some cars are not fitted (intentional?) with cabin filter - sounds like a bad joke on me and some of you who really like Hyundai. So go and check because air quality in the car is really important.
cheers!
