Anyone Try Rounding The Edge Of The Throttle Body? |
Sep 1 2008, 01:13 PM
Status:
Drives: 92 Mustang GT 408w, 08 Accent
QUOTE(fonque @ Sep 1 2008, 01:06 PM) The only way to know would be to flow bench test your throttle body. If you give me some time, I can see if can find an article where some created a flow bench tester in their garage for calibrating MAF's. I dont see why it wouldnt work to test your throttle body. Otherwise the only way to know would be to put it on a dyno.
Not sure how far you are willing to go with this. I personally would not try this unless someone could put up proof it did anything. [right][snapback]187113[/snapback][/right]
Yes, thing is the TB is designed to flow more air than the stock engine needs anyway, in a stock application, the TB shouldn't be a restriction. Even flow testing it wouldn't prove it's any better for the engine though, a say you gain... 10cfm by doing this, totaling 110cfm to keep it simple, engine at peak needs say, 80cfm, you won't notice any gain despite the higher flow rating, and generally a loss will occur if you're flowing too much for what the engine needs, hurting your air-speed through the intake.
This post has been edited by liquid_02: Sep 1 2008, 01:14 PM
Sep 1 2008, 01:23 PM
Status:
Drives: 2008 Tango Red Hyundai Accent
QUOTE(fonque @ Sep 1 2008, 02:18 PM) this is a good read on MAFs from my old forum. But you can use the same setup to flow bench test your throttle body DIY flow bench testif you do some googling, people have set these up using calibrated MAFs, or tubes of water. [right][snapback]187116[/snapback][/right] WOW..he really needs a girlfriend...
Sep 1 2008, 01:33 PM
Status:
Drives: 08 accent
QUOTE(liquid_02 @ Sep 1 2008, 01:13 PM) Yes, thing is the TB is designed to flow more air than the stock engine needs anyway, in a stock application, the TB shouldn't be a restriction. Even flow testing it wouldn't prove it's any better for the engine though, a say you gain... 10cfm by doing this, totaling 110cfm to keep it simple, engine at peak needs say, 80cfm, you won't notice any gain despite the higher flow rating, and generally a loss will occur if you're flowing too much for what the engine needs, hurting your air-speed through the intake. [right][snapback]187114[/snapback][/right]
So much to learn about this motor. do you know how much our motor flows at full throttle? In conjunction, would happen to know the VE for our motor stock?
Sep 1 2008, 01:34 PM
Status:
QUOTE(fonque @ Sep 1 2008, 01:18 PM) this is a good read on MAFs from my old forum. But you can use the same setup to flow bench test your throttle body DIY flow bench testif you do some googling, people have set these up using calibrated MAFs, or tubes of water. [right][snapback]187116[/snapback][/right] Problem with that is it's a very crude way of doing it, accuracy will be terrible, only true way to test CFM is with water, as now everything is controlled. I see an immediate problem with his set-up. His valve he has on there is a flat plate, for what he is doing, to measure properly he would need a butterfly valve of some sort as, a lot of turbulance would be created once that air hit that plate, giving off false readings. Also, what about air temperature, he has nothing to measure and calibrate it for air-charge temp. which is another thing with a MAF. Air gets denser as it gets colder, and less-dense as it gets warmer, same with barometric pressure. All of these have to be accounted for when getting a true flow test. Which is why they use water.
Sep 1 2008, 01:36 PM
Status:
QUOTE(fonque @ Sep 1 2008, 01:33 PM) So much to learn about this motor. do you know how much our motor flows at full throttle? In conjunction, would happen to know the VE for our motor stock? [right][snapback]187120[/snapback][/right]
I'm sure I could figure it out without a problem, give me a few minutes and ill see if I can find bore and stroke for our little fart rocket. VE on any street car is generally 75-85% in the area of 170cfm at 6 grand. at 80VE Had to know all this crap when I built the motor for my Mustang, and kept it fuel injected :\ that was a pain in the **** trying to find everything so it all worked together properly..
This post has been edited by liquid_02: Sep 1 2008, 01:40 PM
Sep 1 2008, 02:04 PM
Status:
Drives: 08 accent
QUOTE(AFireryAccent @ Sep 1 2008, 01:23 PM) WOW..he really needs a girlfriend... [right][snapback]187117[/snapback][/right]
this doesnt even justify a response but if you dont want to learn, then why would you post your mod? I gave you a good place to start investigating if it would actually produce results. So based on your response I can assume you like to make permanent, warranty killing changes to your $10K+ plus car, and not care about whether it did anything??? Sounds like you arent smart enough to have a girlfriend.
Sep 1 2008, 02:07 PM
Status:
Drives: 08 accent
QUOTE(liquid_02 @ Sep 1 2008, 01:36 PM) I'm sure I could figure it out without a problem, give me a few minutes and ill see if I can find bore and stroke for our little fart rocket. VE on any street car is generally 75-85%
Had to know all this crap when I built the motor for my Mustang, and kept it fuel injected :\ that was a pain in the **** trying to find everything so it all worked together properly.. [right][snapback]187123[/snapback][/right]
I was in the same boat when I was investigating going turbo with my last ride. However, I never had to calculate VE for myself, because there was PLENTY of information out there for an SR20, as you might imagine.
Sep 1 2008, 03:54 PM
Status:
Drives: 08 accent
QUOTE(Komptek @ Sep 1 2008, 03:25 PM) I haven't had a good look at our throttle body in sometime, But with my old LC2 when I grinded out the throttle an extra 4mm it did make a diffrance. grinding out hte edges might not do anythign but it might do a little as well. if it doesn't harm anything do it, only way to truely find out. [right][snapback]187148[/snapback][/right]
doesnt harm anything? what about your warranty?
Sep 4 2008, 02:07 PM
Status:
QUOTE(fonque @ Sep 1 2008, 03:04 PM) this doesnt even justify a response but if you dont want to learn, then why would you post your mod? I gave you a good place to start investigating if it would actually produce results.
So based on your response I can assume you like to make permanent, warranty killing changes to your $10K+ plus car, and not care about whether it did anything??? Sounds like you arent smart enough to have a girlfriend. [right][snapback]187129[/snapback][/right]
DUDE! chill out ok? i was only picking...the dude deserves mass respect...**** if my best friend in the whole wide world made this id STILL say it..to his face..then we'd laugh over it hahaha....i guess i have a different sense of humour...having health problems make a person more laid back and laugh a little more at odd things in life haha :P....im sorry, my bad bro so please dont jump at me cuz ive got a sense of humour (not saying you dont..just meant you probably didnt get my joke lol)
Similar Topics
