> '00 Sonata Transmission Problems, Downshfting to 3rd at highway speeds
SoulRebel
post Aug 29 2008, 08:50 AM
Drives: 2000 Sonata GLS
I'm having a problem with my '00 Sonata downshifting to 3rd at highway speeds. Getting the following trouble codes:
P0715: Input/Turbine Speed Sensor Circuit Malfunction
P0740: torque convertor clutch solenoid circuit
P0705: Range switch signal incorrect
The downshifting problem is intermittent and when it happens it seems that only 2nd and 3rd gear are available. Pulling over, shutting the car off and restarting restores normal operation.
My question is this: Should I try replacing the sensors first? I've done some research and seen this downshifting problem attributed to both the Input Speed Sensor and the Range Switch. I've also seen a recommendation to simply flusg the AT fluid. I've also read that Hyundai recommends Transaxle replacement for P0740. Can anyone confirm this?
montego
post Aug 29 2008, 11:52 AM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
this problem is not uncommon, l would drain and refill the trans (use SP111 fluid) and change the input and output speed sensors, this would normally cure the problem if not you may have internal problems in the trans
byronguidry3732
post Aug 29 2008, 12:07 PM
Group Icon
Group: Super Mod
Dear Soul,
Yes, concur with Montego, your transmittion symptoms are now a definite trend for 2000 and 2001 Sonatas. the course of action is correct, choosing cheap fixes first.
1) Transmission fluid exchange with SP-III fluid. Not work?
2) Change the input and output sensors on the transmission. Not work?
3) Have your throttle position sensor checked. this is the expensive one, so don't replace unless it confirms as bad.
Of course, Hyundai recommends you replace the transmission for 0740. If you listen to a service writer long enough, he will recommend replacing the car too. The clutch solenoid circuit can be rebuilt, but this requires a complete transmission rebuild. Current pricing in Colorado for this is a range from $1,400 to $2,000. If you can not eliminate the symptoms with the steps above, you will have to ask the hard question of when do you 'pull the plug' on this car. Try checking your current market price in Kelly Blue Book (kbb.com) and remember that this may just the start of high mileage/high wear problems on your Sonata. I have 110K miles on mine, and not expecting much beyond 160k miles.
Byron
SoulRebel
post Aug 29 2008, 12:26 PM
Wow, thanks for the prompt replies! The output speed sensor was replaced about 3 years ago. Think it's still necessary to change both input and output sensors? Or is it one of those things that should always be done at the same time?
montego
post Aug 29 2008, 12:48 PM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
alot depends on the mileage, has the trans. fluid been changed at regular service intervals?...you could try it step by step, change the fluid first if no difference change one speed sensor and so on
No new Sonata Vs M3, 350z And G35
27 v33sonata 345 Today, 04:51 AM
Last post by: il06gt
No New Posts Sonata Hybrid 2010
Hyundai showed Sonata Hybrid
4 colortv 100 20th November 2008 - 07:13 PM
Last post by: vitacura
No new Topic has attachmentsTransmission Shift Quality In 2009 Sonata
40 dandaroy 1,335 18th November 2008 - 12:08 PM
Last post by: riceR
No New Posts Topic has attachmentsSonata Pics
'07 SE - Silver - Newly added spoiler
19 aj8690 579 18th November 2008 - 11:44 AM
Last post by: wymi
No New Posts Sonata's Michelin Pilot Hxmxm4 Tires
38,000Kms and thread is done?!?
5 theiceage05 87 17th November 2008 - 09:00 PM
Last post by: IHOTI
23rd November 2008 - 07:23 AM
