QUOTE(chad_mac @ Oct 7 2008, 01:34 PM)
well i dont know about the whole "less spool up time" turbo lag seems to come to mind there, and if you want to be making more power than a supercharger can give you, yes go turbo btu at the same time if your going to be running that much power your not just going to be able to slap a turbo on and call it a day, you will probably have to replace the bottom end otherwise $hit$ gunna break...
[right][snapback]195080[/snapback][/right]
Yes indeed. Where as turbos have turbo lags (though in more refined ones it's much less apparent), supercharger boosts throughout the powerband. And like chad said if you want that much power you're gonna need a lot more than just putting in a tubro with high psi. Also, superchargers are capable of decent psi's. Example: The Cobalt SS's Eaton Supercharger (now they changed it to turbocharged) was running 12 psi stock. Granted I'm not an expert on these things; I'm just speaking from what I know. If you still prefer turbo that's perfectly fine, and good luck!
This post has been edited by jlien222: Oct 8 2008, 12:38 AM
