Generally if you add an adder you lose the VVT or VTEC (in a honda's case, I believe they just lock the rocker in place in them though, so it's always riding on the 3rd lobe..) in the motor. You generally don't want to change timing with a power adder, lots and lots of hassle, and you'll never get it tuned properly.
That being said, anything is possible if you have the money, Supercharger would be near impossible in an accent though, as there is just no place to put it, unless you cut a hole in your hood. With a proper turbo set-up, you will have decent low RPM power, and the beautiful thing about a turbo, if you're not using it, you're not wasting power, not putting extra load on your engine, and getting better fuel economy. Where-as a supercharger, there's always that extra draw on the engine whether you like it or not.
In the end, the PCM is always the limiting factor in any installation
This post has been edited by liquid_02: Aug 27 2008, 08:39 PM
