QUOTE(AsmGuru62 @ Aug 27 2008, 04:11 PM)
Just wanted to add something about the "secret" mid-way gears...
...The drop in RPM can mean only one thing (IMO) - there is a gear(s) which is like transfer between main 4 and main 5 - like 4.5.
[right][snapback]185767[/snapback][/right]
It's not an extra gear. The "4.5" you referred to is actually 5th gear. When the torque converter locks a little later, it causes a drop in RPM, almost as if the car were shifting into a 6th gear.
hosed, this would be the same kind of occurrence in your 2008 I4, except you only have four gears. In 4th gear, the torque converter will lock as if there were a 5th gear. That's when the shudder occurs. Like others said, it's a known issue and a simple fix.
