The xg300 is a 2001.
The service tech at the dealer said there was a recall but that it had already been serviced under the recall in 2002 and the next time was going to cost $79 for the diagnostics plus anything else. Likely $200. He's a dick.
In addition, changed the battery in the keyless entry and then it didn't work at all. light comes on when you hold down the button but it won't lock or unlock the doors or open the trunk. The dealer says he needs $39 to rescan the remote. I already said the guy was a dick.
bought a washer motor for $60 and changed it myself
QUOTE(montego @ Mar 1 2005, 01:13 PM)
you don't say how old your xg is. there is a recall on the air bags on models up to 2002. the wiring under the front seat needs re roughting and the air bag light will need turning off on the hyundai scanner. in severe cases the wiring loom may need replacing. your dealer should do this for free. have you changed the batteries on your key remote? sounds daft but some don't. $100 sounds alot to change a washer motor!
[right][snapback]7970[/snapback][/right]
