QUOTE(isaac1909 @ Aug 24 2008, 04:16 PM)
so you think the pvc is a bad idea? Will it hurt the car?
[right][snapback]184953[/snapback][/right]
Theoretically it's a bad idea for your health, BUT I can't imagine that you'd be breathing in hardly ANY of it considering it's directly hooked up to your intake... so it's mostly being sucked into your engine, which should burn off any of the vapors. And if the engine doesn't burn them off, your Catalytic Converter most certainly should. The only time I would ever imagine you MIGHT be at risk is if
1) You run your car for a long time and then shove your head in your hood and breathe really deeply for long periods of time (you shouldn't be working on your car when it's hot anyway)
2) You're sitting still on a hot road (stuck in traffic for instance) and you have the blower on full, and then you switch it to recirculate the air and sit there for a day.
Not that 2's a great idea anyway since it recirculates the carbon dioxide too, so more than likely you'd feel lightheaded or sick from lack of oxygen sooner than you'd feel any effects from any possible escaping vapors from the PVC.
On the other hand, the coupler that I'm using in my setup is made Silicone (that's what Weapon-R includes in their intake setups), so it should never have any issues.
In summary.... You should be just fine, but you may wish to change the PVC reducer to one made from either
1) Silicone
or
2) High Temperature Resistant Rubber.
I know for a fact you can pick up the latter at Home Depot or Lowes, or any other large hardware retailer.
This post has been edited by bloodninja: Aug 24 2008, 03:35 PM
