Sorry I did not get back sooner. I was able to fix it with fuel line. I had a piece in my garage from my project car. I cut out a 12" section of metal steering hose that was bad and then used the rubber fuel line in its place. I secured it with 2 hose clamps at the ends. It's been a few weeks with no signs of leaks. when you cut out the old steering line, make it easier on your self and make the cuts at spots where there is good access, don't limit yourself to the small section of the leak. If you have to buy some hose, I would think the fuel injection hose would be better than standard. I believe it has a plactic membrane inside for holding pressure. Good luck
