Oil Leaking |
Aug 23 2008, 09:35 PM
Status:
Drives: 2006 Sonata (2.4)
QUOTE(kyhwa777 @ Aug 23 2008, 09:17 PM) Ye, I change the O-rings with every oil change. [right][snapback]184811[/snapback][/right]
Are you lubricating the seals with oil prior to installation? Is filter loose or tight when the oil is dripping?
Aug 25 2008, 05:02 AM
Status:
Drives: 08 GLS V6 Sonata
My mechanic has been with Hyundai for many years and happens to be a good friend, told me that my 3.3 v6 doesn't like anything other than 5W-20 and if i switch I may be asking for trouble. I don't believe it matters what brand as long as its 5W-20. I am not sure if the I4s are the same. :thumbsup:
Frank
Aug 25 2008, 05:53 PM
Expert
Status:
Drives: Sonata LX 2006 - Two
QUOTE(kyhwa777 @ Aug 23 2008, 09:55 PM) Yup, Lubricating them and i hand tighten the filter till it stops and give it a quick jerk to tighten it more. . I am going to change the oil this comming weekend. Would it be benificial if I change to a 10W-30 or stick with 5W-20, as 5W-20 is like water. [right][snapback]184823[/snapback][/right]
True, the 5W-20 is like water, but you will still have your leak with the other oils. I had a problem with the so-called "crush" washers - either they were scratched or dirty - causing a nuisance type slow leak. I also thought it might be the 5W-20 since it was the first time I used it. But the leak was mechanical in nature as yours surely is. Maybe, the top (larger) O-Ring is defective or cross fitted or whatever, But I guarantee you a change of oil won't fix a mechanical problem. I have been changing the oil/filters on two LX's for three years now and the whole "cartridge filter" thing is getting a little tiresome - at least they are on top. I just leased a 2008 Ford Taurus which uses a "spin - on" filter so easy to access, a chimpanzee could change it.
Aug 30 2008, 08:45 AM
Status:
Drives: 1996 Caravan and 1998 Neon, and 2007 Sonata LImited V6
Both I and a riend had the same issue and it was that we were not tightening the oil filter cannister cap tight enough, I enfed up using a strap wrench on mine and after I hand tighten it as far as possible, i use the wrench, she will turn with the strap wrench until she bottoms out and then will turn no more.
Aug 30 2008, 03:14 PM
Expert
Status:
QUOTE(kyhwa777 @ Aug 30 2008, 05:30 AM) I brought to them my Fram oil filter and O-rings. They compaired the fram to the genuine Hyundai ones and the hyundai are slightly bigger and look to be made with better quality rubber. [right][snapback]186514[/snapback][/right]
This is an all too common occurrence with second source (sometimes any source) parts. Watch out for stuff from the third world. I noticed that the Purolator oil filters for the Sonata are made in India. Buy at your own risk. Right now, some Chinese plumbing parts are giving me fits. Also, Fram oil filters, in general, have a lousy reputation. On the plus side - oil/air filters at my dealer have dropped quite a bit.
Aug 30 2008, 03:36 PM
Expert
Status:
QUOTE(kn5owa @ Aug 30 2008, 03:14 PM) This is an all too common occurrence with second source (sometimes any source) parts. Watch out for stuff from the third world. I noticed that the Purolator oil filters for the Sonata are made in India.
On the plus side - oil/air filters at my dealer have dropped quite a bit. [right][snapback]186587[/snapback][/right]
Yup, I agree... why buy aftermarket, when you can get a Hyundai filter for like $7 or $8, and not have problems like this... in my mind it's too big of a hassle and risk just to save a couple bucks.
This post has been edited by LilBean: Aug 30 2008, 03:37 PM
Aug 30 2008, 09:04 PM
Status:
Say what you will about third wold filters, but both the MAHLE and MANN oil filters for my BMW 750il are made in India and recommended by BMW
Aug 30 2008, 09:33 PM
Expert
Status:
QUOTE(Raptor @ Aug 30 2008, 09:04 PM) Say what you will about third wold filters, but both the MAHLE and MANN oil filters for my BMW 750il are made in India and recommended by BMW [right][snapback]186676[/snapback][/right]
I would assume BMW monitors the quality. But, I can assure you, based on many decades of experience, that nothing is more frustrating than to finish some complicated, filthy repair job and then find out that the job is botched because of defective parts, and has to be done over again.
This post has been edited by kn5owa: Aug 30 2008, 09:34 PM
