2010 Sonata Hybrid Debut At La Auto Show, new hybrid debut! |
Aug 21 2008, 01:23 PM
Status:
Drives: 2008 Sonata Limited
QUOTE(MABuch131 @ Aug 21 2008, 11:48 AM) It would be nice if it would be a plug in hybrid. [right][snapback]184345[/snapback][/right]
The Sonata hybrid will not be a plug-in hybrid according to various sources.
Aug 21 2008, 01:25 PM
Status:
QUOTE(Valk @ Aug 21 2008, 11:34 AM) Yah I could see them changing the displacemnt and then keeping the horse power around the same as the 4 cyl. I wonder what the price difference will be??? [right][snapback]184339[/snapback][/right]
Hyundai wants market share. The Korean's are smart. Expect Hyundai to undercut everyone.
Aug 21 2008, 02:02 PM
Status:
Drives: 2006 Hyundai Sonata V6 GLS, 2008 Mazda5 GT
QUOTE(mdale007 @ Aug 21 2008, 11:19 AM) I suspect that the fuel efficiency to be up almost 50% — and emissions to be down 37% — when compared with the regular gas-powered Sonata.
I expect the hybrid to have the a cvt transmission, stop/start mode, curb weight reduction, and the LG Chem litium-ion polymer batteries.
Litium-Ion Polymer Advantages: Thinness and form factor flexibility. Higher energy on both a weight and volume basis. Higher voltage than NiCd or NiMH — fewer cells are required to achieve application voltage levels. Ability to create battery with large “footprint” for thin, high capacity applications. Improved safety-more resistant to overcharge; less change for electrolyte leakage.
One would think that the 2.4 theta II would lose displacement either bore or stroke to increase mileage? [right][snapback]184319[/snapback][/right]
They probably are going to adapt it to Atkinson cycle.
Aug 21 2008, 03:15 PM
Status:
QUOTE(szwakon @ Aug 21 2008, 02:02 PM) They probably are going to adapt it to Atkinson cycle. [right][snapback]184377[/snapback][/right]
One could only hope the theta goes atkinson. For those who are not familiar with Atkinson cycle. The Atkinson cycle four stroke piston engine in which the intake valve is held open longer than normal to allow a reverse flow of intake air into the intake manifold. This means the compression ratio is smaller than the expansion ratio. For any given portion of air, the greater expansion ratio allows more energy to be converted from heat to useful mechanical energy meaning the engine is more efficient. The disadvantage of the four-stroke Atkinson-cycle engine versus the more common Otto-cycle engine is reduced power density. Because a smaller portion of the intake stroke is devoted to compressing the intake air, an Atkinson-cycle engine does not take in as much air as would a similarly designed and sized Otto-cycle engine. Prius, Escape, Camry, Tahoe all use the Atkinson cycle.
Aug 22 2008, 01:57 PM
Expert
Status:
Drives: "KC" 06 GLS 3.3L DOB 2-16-06 Bright Silver Metallic
If Hyundai uses a parallel hybrid design, the electric motor is permanently joined to the gasoline motor.
Good news: if they go with an Atkinson cycle, the loss in power can be partially made up with the electric motor, which produces full power from startup. It's also the simplest hybrid design.
Bad news: the electric motor always turns the gas engine, so it loses some power. The Civic hybrid uses the variable valve timing to hold the valves open, reducing the drag. Hyundai will no doubt use the same strategy.
I read somewhere Hyundai is using Li-Ion-Polymer batteries. They store much more energy than the Nickel-Metal-Hydride batteries Toyota and Honda use, so Hyundai won't be competing with Honda and Toyota for batteries. Yeah, them Koreans is smart!
Aug 22 2008, 02:07 PM
Status:
QUOTE(Dennis the Mennis @ Aug 22 2008, 02:57 PM) If Hyundai uses a parallel hybrid design, the electric motor is permanently joined to the gasoline motor.
I read somewhere Hyundai is using Li-Ion-Polymer batteries. They store much more energy than the Nickel-Metal-Hydride batteries Toyota and Honda use, so Hyundai won't be competing with Honda and Toyota for batteries. Yeah, them Koreans is smart! [right][snapback]184592[/snapback][/right]
Hopefully they will use Li-Polymer or at least Li-Ion batteries. That would really reduce a battery pack size. I really like the Altima Hybrid however her trunk is really small because of the batteries.
Aug 25 2008, 07:29 AM
Status:
QUOTE(Dennis the Mennis @ Aug 22 2008, 01:57 PM) If Hyundai uses a parallel hybrid design, the electric motor is permanently joined to the gasoline motor.
It is my understanding that Hyundai is going to use a strong parallel hybrid system. As a result either the battery via the electric motor, or the engine directly to the transmission, or a combination of both, can provide propulsion power. A strong hybrid offers Idle Stop, Regenerative Braking, Motor Assist, and Engine-Off Drive-EV Mode. A mild hybrid system has an advantage of costing less but saves less fuel compared to a strong hybrid.
Similar Topics
Similar Topics
