> Wiring Diagrams, 2008 Sonata wiring - color coding
eddietel
post Aug 17 2008, 11:04 PM
Drives: 2008 Hyundai Sonata GL Premium 2.4L Bright Silver Black and Grey Interior, 2007 Suzuki Silver Swift+
Does anyone out there have the colour codes for the wiring at the brake, running and turn lights in the trunk space.
I need to hard wire a harness and would like to check out the color coding of the wiring before starting out.
bumer325
post Aug 19 2008, 09:40 AM
Drives: Hyndai Sonata 2006
go to alldata.com they have everything
Dennis the Menni...
post Aug 21 2008, 08:21 AM
Expert
Drives: "KC" 06 GLS 3.3L DOB 2-16-06 Bright Silver Metallic
Better to use a tester (AutoZone has them) because the wiring guides are often wrong or difficult to interpret. Start with a turn signal and probe the wires in the trunk until you find the one that flashes your tester to the beat of the directional.
Fair warning: the Sonata uses something called "Negative Triggers" for all lighting. You won't be able to wire your trailer directly to the cable. You need an adapter (it's sometimes called a "diode bridge") between the wires in the trunk and the plug for your trailer. The shop where you bought your trailer hitch should be able to help.
This post has been edited by Dennis the Mennis: Aug 21 2008, 08:22 AM
eddietel
post Aug 23 2008, 10:07 PM
QUOTE(Dennis the Mennis @ Aug 21 2008, 07:21 AM)
[right][snapback]184301[/snapback][/right]
I would assume by diode bridge, you mean the harness I got from my dealer. It takes the 3 circuit system in the Sonata (Brake, Turn, Running) and creates a two circuit (Brake/Stop & Running) system. I finally came to the conclusion that I would have to trace all the wiring manually and this is the week-end to get at it.
Thanks for the info.
Dennis the Menni...
post Aug 24 2008, 12:55 AM
Expert
Yes. Good luck and don't hesitate to ask if you have questions.
This post has been edited by Dennis the Mennis: Aug 24 2008, 12:55 AM
robtemple
post Aug 26 2008, 11:54 PM
Drives: 2002 Accent
I'm surprised no one mentioned hmaservice.com (Hyundai Motor America service information dot com) for your wiring question. This is a completely free information service offered by Hyundai, but few seem to take advantage...
eddietel
post Aug 27 2008, 03:21 PM
QUOTE(robtemple @ Aug 26 2008, 10:54 PM)
[right][snapback]185625[/snapback][/right]
I checked this source and they do not have colour coding information - lots of good stuff but not this. Some earlier mentioned it could be because of spec changes that they choose to not publish colour coding.
robtemple
post Aug 28 2008, 12:59 PM
Drives: 2002 Accent
QUOTE(eddietel @ Aug 27 2008, 01:21 PM)
[right][snapback]185747[/snapback][/right]
You need to go to the "ETM" tab to get color codes. I just checked and it is there for the 2008 NF.
No New Posts Wiring Harness Help !
Ignition Coil Harness Disintergated
0 Yusef71 13 30th November 2008 - 06:30 AM
Last post by: Yusef71
No New Posts Wiring Diagrams
where to find them
2 woobiesue2 161 2nd November 2008 - 02:17 PM
Last post by: RetsaM
Wiring Circuit Daigram
0 atc 364 4th October 2008 - 10:27 AM
Last post by: atc
2 DCOWBOYS1975 458 13th August 2008 - 03:44 PM
Last post by: MiamiLX
Where's the wiring harness?
6 SLEBOLD 398 4th August 2008 - 12:29 AM
Last post by: david-paul-1
4th December 2008 - 11:39 PM
