2 Pages V   1 2 >
> Outside Of Tires Worn Down! Why?
PaulW
post Aug 13 2008, 05:15 PM
Drives: 2006 Hyundai Sonata LX
Hi all! Today I noticed that the outside of my two front tires are worn down a ton to the point that I should replace them. The middle and inside of the tires have a ton of tread left. What would cause this? Any of you experience this on your Sonata's?
These are the OE tires with 37k miles on them.
I had the tires rotated so I'm good up front at least for now. I wonder if this is an alignment issue?
Thoughts?
ddix1026
post Aug 13 2008, 05:18 PM
Lonely Commuter
Status: Online
bent axle maybe? i havent had the issue, and my OEM tires have about 45k miles on them (with probably another 20k-30k before they would need to be replaced)
alfu
post Aug 13 2008, 05:19 PM
Drives: 07 SONATA SE
have u ever aligned the car since you got it?
i had the dealer algin mine like 2 months after buying it. (free)
PaulW
post Aug 13 2008, 05:37 PM
No I have not. I'll make sure to have the dealership look at it when I take the care in for an oil change. Maybe I should take it in sooner thou...
dwnthehatch
post Aug 13 2008, 05:46 PM
Drives: 2008 Santa Fe SE
Underinflated tires
Attached File(s)
alfu
post Aug 13 2008, 06:04 PM
QUOTE(dwnthehatch @ Aug 13 2008, 05:46 PM)
Underinflated tires
[right][snapback]182782[/snapback][/right]
it cant be under. if it wer under it wud be worn on both inside and outside. his are just wearing outside.
its probly toe or camber wear/
This post has been edited by alfu: Aug 13 2008, 06:10 PM
Perry Manessis
post Aug 13 2008, 06:32 PM
Drives: 06 Sonata GLS 2.4 P/S & 07 Santa Fe 3.3 Limited T/P (wife's ride)
It may possibly be the alignment, but my money is on hairy turns. Remember, these Michelins are made for long lasting normal driving. (granny style). Any little bit of enthusiastic driving will eat them up. I know this from experience, I have the same thing, 34,000 miles and the out tread blocks are down to the indicators but the middle and inside are fine. The alignment is fine. The problem is I take turns and they howl worst than a wolf. Even with them inflated to 35 PSI. I will be going to a more aggressive tire and doing a Lus Zero. Going from a 215/60/16 to a 235/55/16. I probably will be getting the Sumitomo HTR H4. Here's a link to Tire Rack.
http://www.tirerack.com/tires/tires.jsp?ti...re1=yes&place=0
PaulW
post Aug 13 2008, 06:51 PM
Alfu you are right about it ONLY being on the outside, not the inside. I have upped the tire inflation to 35 PSI from 30 to see if it helps.
I guess it's time of an alignment? I've never hit anything, should a car with 37k miles be out of alignment yet?
Paul
LilBean
post Aug 13 2008, 07:35 PM
Expert
Yes, it's alignment, worn on the outside would be too much positive camber. The alignment tends to get out of spec with time. Alignments are a maintenance issue after like 12k miles. Regular rotation won't affect something like this, you will have to get an alignment. Tire inflation also will not affect this. Just make sure you keep your tires inflated to the recommended pressure.
This post has been edited by LilBean: Aug 13 2008, 07:36 PM
TheGetter
post Aug 13 2008, 07:44 PM
Drives: 2006 Sonata LX
Sounds like alignment
My dealer say's hyundai recommends every 15,000 miles but they suggest 20,000 to 25,000 miles
Increasing tire pressure to 35lbs will only give you a harder feeling ride.
alfu
post Aug 13 2008, 08:12 PM
Post #11
if its a gradual wear from inside out its camber if not its mostlikely toe
look at pics below
Attached File(s)
craigbrooks
post Aug 13 2008, 09:28 PM
Post #12
Just hangin' out...
Drives: 2006 Hyundai Sonata GLS F24S (DOB 04/30/05), 1997 Mustang V6 Convertible
QUOTE(PaulW @ Aug 13 2008, 05:51 PM)
Paul
[right][snapback]182792[/snapback][/right]
..and new tires. Do a search here for tire info, lot's of choices and opinions. :thumbsup: Comfort and performance choices abound. :amen:
You say you've never hit anything. How about those concrete parking stop things? Potholes? Etc... These things can throw an alignment out of whack and cause wear like this. BTW what position is your steering wheel in when the tires appear straight?
PaulW
post Aug 14 2008, 11:44 AM
Post #13
QUOTE(craigbrooks @ Aug 13 2008, 07:28 PM)
[right][snapback]182819[/snapback][/right]
I live in Arizona and we have good roads so I don't have to worry about pot holes and the like. I did by this used so I can't say what the previous owner did with it.
As far as the steering wheel it seems to be a little to the right of center when I'm driving straight.
PaulW
post Aug 14 2008, 12:45 PM
Post #14
QUOTE(LilBean @ Aug 13 2008, 05:35 PM)
I've been reading up on this a bit more here: http://www.familycar.com/alignment.htm
They state the following:
"On many front-wheel-drive vehicles, camber is not adjustable. If the camber is out on these cars, it indicates that something is worn or bent, possibly from an accident and must be repaired or replaced."
Does anyone here know if the camber is adjustable on the Sonata?
craigbrooks
post Aug 14 2008, 09:17 PM
Post #15
Just hangin' out...
Not sure if it's adjustable but there are references to a +/- in the following TSB. Makes you wonder.
http://sonata.jerrystout.us/tsb/alignment%20specs.pdf
babstude
post Aug 15 2008, 08:04 AM
Post #16
Drives: 2006 Sonata
I have a feeling everyone is over analyzing this "problem" .. dude - you are taking corners too fast !!!
PaulW
post Aug 15 2008, 09:34 AM
Post #17
At times I could be yes but not regularly to have this level of wear I think. I'm going to take it into the shop next week so we'll find out hopefully!
Paul
This post has been edited by PaulW: Aug 15 2008, 02:29 PM
normandelli
post Aug 15 2008, 09:38 AM
Post #18
Expert
Drives: 2006 Sonata GLS Sport
I can answer this definitively. NO it's not.
:thumbsup: -N-
QUOTE(PaulW @ Aug 14 2008, 01:45 PM)
[right][snapback]182952[/snapback][/right]
cantfoolthewise
