> Clogged Windshield Wiper Reservoir, need assistance
whodathought
post Aug 13 2008, 03:19 PM
Drives: 2007 Santa Fe
Has anyone any ideas on how to remove gunk that is in my windshield washer reservoir without going to all the trouble of removing the fender or whatever is involved? I'm thinking something like mild Draino.
Its a 2007 Limited.
Front windshield gets no liquid at all. Rear windshield gets a small burst then nothing.
Thanks in advance,
Jim
Don67
post Aug 14 2008, 12:48 AM
Drives: 2008 Santa Fe GLS AWD
Poking a needle into the washer nozzle, wiggling it around, then spraying, then repeating several times, has always worked for me in the past.
Failing that, you might disconnect the hose from the nozzle and try blowing compressed air. If you suspect debris in the tank, try flushing it with a garden hose (making sure the water is gone before winter), or vacuuming it dry with a siphon pump.
I would avoid Draino. Anything that can burn human skin is probably not good for rubber hoses and electric pumps either.
Good luck!
montego
post Aug 14 2008, 01:09 PM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
you will likely find that the filter in the washer pump is blocked, you will need to remove it to clean it out, the motor is mounted under the right hand front wing/fender under the plastic shield
terkar
post Aug 29 2008, 10:14 AM
Expert
Drives: 2009 mercury milan, 2007 Santa Fe limited, and 2009 Mustang
Mine does the same thing---the dealer blew compressed air and it still does not work---so its going back for a new pump. I think others have had their washer pumps crap out. They make noise but don't pump anything.
whodathought
post Aug 29 2008, 11:52 AM
QUOTE(terkar @ Aug 29 2008, 10:14 AM)
[right][snapback]186270[/snapback][/right]
Did the dealer work on it under warranty?
terkar
post Aug 29 2008, 02:07 PM
Expert
YES!!!! Apparently the pumps are defective.
whodathought
post Aug 29 2008, 03:03 PM
QUOTE(terkar @ Aug 29 2008, 02:07 PM)
[right][snapback]186348[/snapback][/right]
Thanks, will probably get mine taken care of next week.
whodathought
post Sep 5 2008, 07:48 AM
Had the whole unit replaced yesterday, under warranty. Noticed that the stream from the passenger side nozzle now only comes part way up the windshield. Service manager stated that the nozzle was not adjustable and that perhaps there was some crud still blocking the line and to give it a try for a little while to see if it clears. If not then they would replace the nozzle.
Is he correct that the nozzle can not be adjusted to point higher up the windshield?
Whoda
RJ Canuck
post Sep 5 2008, 11:26 AM
Drives: 2007 Hyundai Santa Fe 3.3 GLS AWD 5-pass
Hi Whoda,
You can adjust the spray nozzle.
"Wiper fluid nozzle adjustment – very carefully put a pin in a nozzle to re-direct the aim of each individual nozzle."
I found this in thread: http://www.hyundai-forums.com/index.php?sh...14788&hl=nozzle
We've adjusted our front washer spray using this technique and it works well.
No New Posts Wipers Working Very Sloww On My 2002 Accent
1 2002accent32 9 Yesterday, 08:51 AM
Last post by: montego
No New Posts Topic has attachmentsWindshield Washer Sprayer Chrome Covers
There must be some out there, somewhere?
1 James51 242 12th November 2008 - 06:24 PM
Last post by: James51
No New Posts Wiper Arm Tension
How to adjust
2 crustyone 98 25th October 2008 - 08:34 AM
Last post by: crustyone
No New Posts Windshield Wiper Issue
7 Michael6729 203 26th September 2008 - 06:34 PM
Last post by: ddix1026
No New Posts Windshield Replacement: Oem Or Generic?
Windshield replacement: OEM or generic?
10 nw07heavy 737 6th September 2008 - 06:41 AM
Last post by: andyman32
23rd November 2008 - 03:18 PM
