> Spark Plug Heat Ranges For The V6 Sonata
v33sonata
post Aug 12 2008, 12:52 PM
Sonata Perfromance Expert
Status: Online
Drives: Fastest 3.3L Sonata!
Anyone know why Hyundai would put a colder plug in the 2006 then in the 2007 model?
babstude
post Aug 12 2008, 08:07 PM
Drives: 2006 Sonata
the '07 gets slightly better mileage right ? I suppose it burns hotter and more efficiently hence the different plug ?? just an edumucated guesstimate
v33sonata
post Aug 12 2008, 11:58 PM
Status: Online
QUOTE(babstude @ Aug 12 2008, 08:07 PM)
[right][snapback]182605[/snapback][/right]
Does it? I do know its a hotter plug. Heres a question when using nitrous they say use a colder plug now assuming I had an 07 with the same motor I would just have to use the 06 plug. So what if I have an 06 should I still go down one colder?
mdale007
post Aug 13 2008, 07:53 AM
Drives: 2008 Sonata Limited
QUOTE(v33sonata @ Aug 12 2008, 11:58 PM)
[right][snapback]182633[/snapback][/right]
Yes, drop one heat range for every 75 shot of Nitrous. Less than 75 shot on the street one step cooler should be sufficient. Large amounts of Nitrous on the street require switching plugs in and out. Use a hotter plug when running only the motor and a cooler plug for nights when you decide to run nitrous.
Optimum spark plug firing temperatures are 500 degrees - 800 degrees Celsius. If the spark plug tip temperature falls below 450 degrees the spark plug is considered to be in the fouling range. If the temperature rises above 800 degrees the spark temperature is considered to be too hot and the spark plug is considered to be in pre-ignition.
As you know pre-ignition is detrimental to an engine and can ultimately lead to spark plug damage and extensive engine damage.
No new Sonata Vs M3, 350z And G35
29 v33sonata 371 Today, 01:30 PM
Last post by: hugamuto
No new The Effects Of Going 100+ Mph In A Sonata
"There has been a fatality. The guy is in half"
59 alex2006sonata 679 Today, 08:02 AM
Last post by: cmerica
No New Posts The Genesis Alternative... For Less
20 07 Santa Fe 1,105 Yesterday, 01:44 PM
Last post by: Propflux01
No New Posts Sonata Hybrid 2010
Hyundai showed Sonata Hybrid
4 colortv 102 20th November 2008 - 07:13 PM
Last post by: vitacura
No New Posts Heat For The Cabin
what is the normal temp?
0 Hyundai_81 12 19th November 2008 - 06:34 PM
Last post by: Hyundai_81
23rd November 2008 - 03:43 PM
