 Hyundai-Forums.com > Hyundai Models > i30 Forum
> 1.6 Crdi Diesel Filter, How does one change this filter?
dham
post Aug 12 2008, 12:13 AM
Drives: 2008 Hyundai i30 SX 1.6 CRDi
Have had our i30 1.6l crdi for about six months now and am very pleased with it. I have always serviced my own vehicles (often in remote areas) and have plenty of experience with diesel 4wd's in particular. However, looking at the i30 engine bay, I can't see how to easily spin off/on the diesel cartridge filter as it has a 'shroud' around it. Is there some sort of trick to this - am sure that it can't be too complex! Maybe one has to remove air intake pipes to make room? Certainly the oil filter is easy to replace and there is no reason that the diesel filter should not also be.
Any advice on diesel filter removal would be much appreciated!
dham
tjaliwalpa
post Aug 12 2008, 01:46 AM
Drives: 08 i30 CRDi 1.6 Manual / 09 Santa Fe CRDi 2.2 Auto
dham,
Not certain how to replace filter, but I do know it is a cartridge type similar to most diesel 4WD engines. It does look rather hard to get at I know. I had my whole filter unit replaced under warranty to fix a problem that caused the motor to limit itself to about 2900rpm due to air bubbles forming in the fuel filter (so I was told).
Bob
dham
post Jan 26 2009, 06:18 PM
OK - have done it!
1. Remove air duct between airbox (airfilter) and turbo (c/w hose from rocker cover) to make space.
2. Disconnect both fuel lines to filter (pull out orange catch, push in blue tab, pull off line).
3. Disconnect all three wiring connections to filter assembly.
4. Remove the four nuts holding the whole shroud bracket and filter assembly to bulkhead (need a deepish 12mm socket).
5. Lift out complete filter assembly, unbolt filter from shroud bracket, unscrew filter and replace with new one.
6. Reverse above process to refit!
Long winded compared to most other diesel filters but not hard to do.
dham
No New Posts Diesel Particulate Filter
2 StoneIce 226 26th July 2009 - 07:17 AM
Last post by: wingas
No New Posts Diesel Workshop Manual
1 mayday65 282 7th May 2009 - 11:05 PM
Last post by: accent sport
No New Posts Diesel Particulate Filters
0 wingas 108 10th April 2009 - 07:12 AM
No New Posts 16" Stock Accent Mags Offset
What is the mag offset ?
5 Chimaira 416 25th March 2009 - 07:56 PM
Last post by: fonque
No New Posts Filters Source
7 fishmn 924 11th March 2009 - 04:19 PM
Last post by: Gamle-ged
7th November 2009 - 08:08 PM
Privacy Statement
