I've read through the archives and the issue of DIY timing belt changes has come up and the recurring answer is always that the timing belts are a huge PIA and way more troublesome than other makes/models.
What exactly makes that so? Is it that there is so much stuff to remove to get to it, or something else?
I've got a ton of stuff off of my engine right now so that I can do some other things including drive belts, and a timing belt is needed. My intake is out for spark plugs/wires/coils, my air cleaner box is out for a P/S hose replacement, the drive belts are off for replacement, and the right axle is out for replacement. So is there another consideration that should keep me from pulling more stuff out and doing the timing belt too?
This post has been edited by wmcraftXG: Aug 11 2008, 10:27 PM
