H&r Or Eibach? Can't Decide! |
Aug 11 2008, 06:13 PM
Audio geek
Group: Super Mod
Status:
Drives: 2006 Sonata GL V6
Tough to compare without having had both, but I prefer Eibach from my limited experience with H&R.
Based on two mustangs owned by friends of mine, the Eibach seems to be more streetable and the H&R seem stiffer and lower. This is only slightly applicable to the sonata, since they are two very different types of cars, but I have heard that it is a fair generalization, Eibach being slightly softer and more pleasant and H&R being rougher and lower.
Aug 12 2008, 12:10 PM
Status:
I have Eibachs and think they are excellent. They are much firmer than OEM and not one bit harsh. They absolutely improved the feel of the car.
However, here is something I emphatically suggest you consider. And if you select the slightly firmer H&Rs, this issue becomes more important. Our OEM struts/shocks are a terrible match for the stiffer springs.
When my car hits a bump, the firmer springs handle the compression much better than OEM. But once the springs compress, they have to release all that energy back up. Because they are stiffer springs, they release the energy quicker and our weak OEM struts don’t control the upward motion that well.
As a general statement, one of the biggest jobs of the strut/shock is to dampen that rebound. If a spring overpowers the dampening power of a strut, the car bounces back up too quickly. That can make the car feel a little wobbly. I think that is a minor problem with my Sonata. With the Eibachs, the down motions are very well controlled but the up motions feel a little jerky.
To do the job correctly, we should really replace the springs and struts, so they remain matched. If you change just the springs as I did, the car will certainly feel better, but never feel really good.
Sadly, no manufacturer makes “higher-performance” struts/shocks/dampers. I know coil-overs exist that should do a far superior job than lowering springs, but they cost about $1,000 before installation. If you are really serious about improving the ride and intend to keep the car for many years, I would suggest that you save your money for a few more months and buy the more expensive coilovers. Although I am still satisfied with my Eibachs, I wish I had done that. Do it right the first time. No compromises.
Aug 13 2008, 04:42 PM
Audio geek
Group: Super Mod
Status:
QUOTE(vermontsonata @ Aug 13 2008, 11:00 AM) I like Coke better... :P [right][snapback]182731[/snapback][/right]
That's because it is better :) But that's a topic for the off topic lounge :D
Similar Topics
Similar Topics
