I have a 99 tiburon with a 2.0 4 cyl. Just started last week and the noise has been increasing. Only happens as I shift it into first and second gear and stops after that. As I let off the clutch going from neutral to 1st it sounds like the engine bogs down or has a tougher time to accelerate. Then the same into second. Once it gets moving into 3 gear and higher it goes away. I do not get that noise if its in neutral and i accelerate or if I roll down a hill. It sounds kind of like a slight grinding noise. or something loose between the tranny and engine? I was going to check the transaxle oil to make sure there was enough fluid in there thinking it may be from low oil. This car has about 175K on it.
Thanks for help
This post has been edited by mattg997: Aug 11 2008, 01:47 PM
