QUOTE(Glock23 @ Aug 14 2008, 12:27 PM)
This is for people wanting to run a full car audio system. Not some lame **** 600 watt amp and some cheap subs.
[right][snapback]182946[/snapback][/right]
wow how does wattage amount = lame?
and who said the 600 watts was going to a sub?
and please for my plebian mind, define "full car audio system"?
I have read alot of your posts on this forum, but this is the most unintelligent post I have read from you. If you disagree with my opinion, then prove me wrong and cite some resources. Come back at me with an intelligent rebuttal, because right now you just look ignorant with a limited understanding of car audio.
A system running a solid 600 watts (with gain levels set with a DVM, no guess work). Even including efficiencies of class a/b and class d amps (I am making the assumption that no one on this forum is running class a) you are looking at approx. 50 amps. with the car running 600W x 14.4V x 1.2(efficiency) = 50
Also remember current draw is volume dependant, you are only going to see max current at max volume if your gains are set properly. At reasonable listening levels you will typically see 25 percent of that current draw with spikes on heavy bass notes.
If you cannot properly articulate why your product is needed then why are you selling it?
This post has been edited by fonque: Aug 14 2008, 09:03 PM
