> Musty Smell Not Ac, MUSTY ODOR SMELLS LIKE WET BASEMENT
HOND-EYE
post Aug 11 2008, 09:35 AM
Drives: 2003 HYUNDAI SANTA FE 2.7
[FONT=Geneva][SIZE=7][COLOR=blue]After 3 years of trying to track down this smell, (mostly present in the summer months) I finally tracked down the culprit. IT IS NOT THE AC OR HAS NOTHING TO DO WITH THE AC/HEAT VENTS. THE SMELL seems to come from the vents but IT IS NOT THE VENTS -- THE PROBLEM IS 1 or 2 DEFECTIVE FREEZE PLUGS IN THE REAR OF THE AUTO. Look underneath the trunk (IF SANTA FE it's 2 RUBBER PLUGS UNDER THE REAR CABIN, next to spare tire) you will see rubber plugs in the sheet metal body. When you remove the rubber plugs you will see the ground through the inside of auto. These plugs leak and water is getting into the cabin. The Santa Fe has sound insulation that is absorbing the water & turning moldy. You will have to completely disassemble the plastic storage compartments in rear, many screws & plastic snap on fasteners. Once you get to the FOAM it will be soaking wet & IT SMELLS LIKE ****. TEAR the wet foam out completely and spray the remaining fabric with lysol or fabreeze. Then USE High grade RTV silicone to SEAL the plugs. Make sure you coat the entire rubber plug - I even glued a thick piece of plastic over the silicone coated plug as back up to prevent water from getting back inside the REAR cabin. I chose not to replace the foam but you can put any similar material in its place. Email me if you have questions. aralight@netzero.net GOOD LUCK. ROB
byronguidry3732
post Aug 11 2008, 12:29 PM
Group Icon
Group: Super Mod
Drives: 2009 Kia Sorrento 3.3, 2008 Sonata 2.4, 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7
:00000732: HOND-EYE,
I have never heard of any rubber body panel plugs in the trunk of floor pans of any Hyundai leaking as you have described...that had not been driven in water 2 feet deep. Sorry, but you must have taken a dip in the pool.
Thanks for the advice on a fix.
Byron
HOND-EYE
post Aug 11 2008, 02:43 PM
Well genius, there is a first for everything. Now you have heard of water getting into cabin of vehicle that has not been in 2 feet of water ! I posted this to help others who may experience same problem , not to be ridiculed as a ****.
byronguidry3732
post Aug 11 2008, 04:05 PM
Group Icon
Group: Super Mod
QUOTE(byronguidry3732 @ Aug 11 2008, 01:29 PM)
[right][snapback]182288[/snapback][/right]
Still thanks for the advice.
http://en.wikipedia.org/wiki/Ridicule
Not a bad movie.
Byron
lovemysantafe
post Aug 14 2008, 05:10 AM
Group Icon
Group: Super Mod
Drives: '04 Santa Fe GLS 4WD (Born 5.24.04)
Wow... :closedeyes:
doggie71
post Nov 19 2009, 05:23 PM
Drives: 2001 santa fe v6
I think have a water problem getting into the cabin. Not sure where yet but after I took out the drivers seat and lifted the carpet I saw quite a bit of standing water that had soaked the foam and sound barrier felt. Is there a rubber plug near the front of the drivers seat side under the steering wheel section or along bottom side? Thanks
No New Posts Accent 95 Has 2 Radiator Fans ?
0 CarlosFreitas 7 Today, 08:16 AM
Last post by: CarlosFreitas
No New Posts Accent Engine Swap
Accent engine swap 1.5
6 xxnamxx 230 16th March 2010 - 09:02 PM
Last post by: 1x32go
No New Posts Not So Great Review Of 2011 Sonata Gls
2 -Guest_LemonLaw_*- 180 15th March 2010 - 08:10 AM
Last post by: -Guest-
No New Posts Accent Spares/repairs
0 craigy 22 15th March 2010 - 07:46 AM
Last post by: craigy
No New Posts Not Very Happy
10 HyundaiLvr87 402 13th March 2010 - 05:57 PM
Last post by: david-paul-1
19th March 2010 - 09:11 PM
Privacy Statement
