QUOTE(duke @ Feb 26 2005, 05:02 AM)
when you stand in front of the radiator, were is the oil leak ?? If the engine is so dirty that one can't determin it, then have the engine cleaned first.
In some cases, we had oil leaks at the head gasket between the block & head, which was fixed by just retorquing the head.
[right][snapback]7770[/snapback][/right]
Well the engine is pretty clean. I noticed the leak because you can see a trail of oil when the car is parked and sits, nothing though when you're just driving around and parking for a couple hours. If it just needs retorquing is that an expensive fix?
