> Ticking Noise When Starting Santa Fe, What Would It Be From?
Hyundai_81
post Aug 9 2008, 12:25 PM
Drives: 2006 Hyundai Santa Fe GLS 2.7L 2WD(Black And Dark Grey)
I Have a ticking noise coming from the front when I first start up the vehicle and only lasts for 5-10 secs maybe 15 secs tops.. I assume I think its from the engine..any ideas?
david-paul-1
post Aug 9 2008, 04:22 PM
Expert
Drives: 2008 Chrysler Sebring Convertible Pearl Marathon Blue, 2007 Santa Fe Limited Pearl White
QUOTE(Hyundai_81 @ Aug 9 2008, 10:25 AM)
[right][snapback]181926[/snapback][/right]
My 07 clatters for about 2 seconds or less. That sound is dry lifters waiting for full oil pressure.
If yours is taking as long as 10 seconds, there is something wrong. Usually the first thing to check is your oil level. If too low, you can get excessive lifter clatter.
The second thing is clogged oil passages to one or more lifters usually caused by dirty oil or infrequent oil changes.
Thirdly, you could have a hydraulic lifter or two starting to ware out.
David <><
This post has been edited by david-paul-1: Aug 9 2008, 04:24 PM
Hyundai_81
post Aug 9 2008, 10:49 PM
ahh ok thanks for your help david-paul-1 first I will get my oil changed I have always had my oil changed on time since the day I bought it brand new.. I just hope there isn't anything wrong with it, oh god I have had problems allready and its only 3 years old (2006) so far break light switch, tensioner pulley and back door handle all replaced and only have 65,000 kms on it and there is also a slight nock in the alternator and the dealership said it will be fine.. ya fine my **** well I am glad I got the extended warrenty, sigh phew
btw could it be from lack of oil pressure and maybe a oil pump going??
This post has been edited by Hyundai_81: Aug 9 2008, 10:50 PM
david-paul-1
post Aug 14 2008, 02:43 AM
Expert
QUOTE(Hyundai_81 @ Aug 9 2008, 08:49 PM)
[right][snapback]182016[/snapback][/right]
Not likely to be an oil pump.
The Santa Fe may have mechanical lifters. I haven't researched this subject since mine is still behaving itself.
If they are mechanical, and continue to clatter, there is a possibility that adjustment is necessary.
David <><
Hyundai_81
post Aug 14 2008, 09:14 AM
oh ok thats good.. I am glad to hear its not likely to be the oil pump going..and that it might just need a bit of a adjustment. thanks again david-paul-1
byronguidry3732
post Sep 14 2008, 09:03 PM
Group Icon
Group: Super Mod
Hyundai_81,
Your 2.7 liter has hydraulic lifters. Have you ever had your engine professionally flushed??? I do this every 30-35K miles as routine. You want to have this done at a shop....not Jiffy Lube...that uses the Texaco Havoline engine flush. This is a motor oil base with solvent and detergent...not kerosene or Marvel Mystery Oil.
It is pricey, probably $50 bucks, but it does a thorough job. Your noise is likely from clogged oil galleries, not from a low oil pressure output from your oil pump. This will show as a warning light for low oil pressure, the red silhouette oil can, on your dashboard.
A little history....the Chrysler 2.7 liter is famous...notorious with lawsuits galore...for sludge build up in the oil galleries. What does this have to do with Hyundai? Look up Global Engine Manufacturing Alliance on wikipedia. The roots of our 2.7 liter engine development trace back to joint engine development with Chrysler of the original 2.5 liter Delta.
Also, my nephew blew his 2.7 liter engine in a Plymouth Sebring at 67k miles from lack of routine oil changes and never getting his engine flushed.
Get it flushed, twice if needed.
Byron
Hyundai_81
post Sep 14 2008, 09:38 PM
thanks byronguidry3732 for the advice, I will be sure to look into that. and it hasn't done it since though, very strange. but I am keeping a eye on it and looking in the service manual and see what it says for an engine flush.. that way if I am not at the km's for one and the motor blows it should be under warrenty providing it says when to do that.. if not I will have to get it done real soon.
No New Posts Ticking Sound From Engine When Car Is Cold?
0 2002accent32 1 Yesterday, 03:29 AM
Last post by: 2002accent32
5 ptt 178 21st November 2008 - 03:43 PM
Last post by: whst0420
No New Posts Santa Fe Items For Sale
2 HyundaiLvr87 227 20th November 2008 - 09:36 PM
Last post by: DeeGee
No New Posts When Is The Esc Supposed To Work?
When is the ESC supposed to work?
8 Sonata08_BGM 137 19th November 2008 - 05:06 PM
Last post by: Sequoiasoon
No New Posts Starting Car Up
6 jj8900 84 19th November 2008 - 06:06 AM
Last post by: cmerica
23rd November 2008 - 03:49 PM
