 Hyundai-Forums.com > Hyundai Models > Getz Forum
> A/c Switch Replacement, Green light is off
tuli
post Aug 9 2008, 01:52 AM
Drives: Hynday getz 1.3 2005
Hello
The green light on the A/C switch is always off, need help describing how to replace the switch
Tuli
MEMTEK
post Sep 14 2008, 02:45 PM
Drives: 2002 Hyundai Accent 1.6
The green light in my 2002 Accent's A/C switch has burned out too. I am going to pull out my car's center panel and see if the bulb can be easily replaced or whether I will need to get a new A/C switch. If an exact replacement bulb isn't available, then I will search for a suitable replacement bulb and let you know if I find one. :)
MEMTEK
post Sep 14 2008, 08:41 PM
I removed the A/C switch from my 2002 Hyundai Accent. It turns out that two small 3mm diameter 12V incandescent bulbs with wire leads are used for illuminating the word "A/C" and for separately illuminating the green indicator which indicates when the A/C system is turned on. The green tint comes from a separate green filter. Both bulbs actually are white. I am not sure what wattage these tiny 12V bulbs are, but one bulb is slightly longer than the other.
Following is a photo showing my car's A/C switch, the bulbs, and the bulb holders. The bulb leads are simply wrapped around two posts on the bulb holders and then any excess wire is snipped off. To remove the bulb holders, use a small screwdriver to rotate them about 20 degrees counterclockwise until they stop. Then use a really small jewelers flat head screwdriver to lift the bulb holders out of their sockets in the switch.
(IMG:http://i288.photobucket.com/albums/ll200/MEM-TEK/2002_Hyundai_Accent_AC_Switch_Bulbs.jpg)
Following are links to two sources which I found for some 3mm diameter 12V bulbs with wire leads. One source has 35mA bulbs, and the other source has 50mA bulbs which would be a bit brighter. I am going to order two of each, figuring that one or the other should provide the ideal brightness.
12V 35mA Micro Lamp 0.12" 3mm Dia.
12V 50mA Micro Lamp .6W 3mm Dia.
8 cantfoolthewise 129 17th November 2008 - 11:11 AM
Last post by: cantfoolthewise
No New Posts Acceleration Issue Driving Wallet And Mechanic's Nuts!
19 dennis09 375 15th November 2008 - 02:20 PM
Last post by: bobad
No New Posts Accent 97 Gearboxes
1 droo15 41 10th November 2008 - 05:31 AM
Last post by: Pintu
27 PastorK 809 7th November 2008 - 06:37 PM
Last post by: PastorK
No New Posts Acceleration Vibration
3 dasia702 86 7th November 2008 - 02:31 PM
Last post by: TroyHansen
23rd November 2008 - 02:59 PM
