> Anyone Have Mileage Drop After Injector Cleaner, wierd mileage drop
Tango2Go
post Aug 8 2008, 01:32 PM
Drives: 2007 Hyundai Accent GS
I normally get 33.5-34 mpg's.
As it got warmer with someone driving me around it dropped to 32.
The first tank after I put on the SRI and Muffler it jumped to 37(though mostly highway)
So I figured I would add some injector cleaner to the next tank(never added in the 22,000 previous miles).
Next 2&1/2 tanks were 30.2,30.2,and31.6(after oil change).
Could the injector cleaner maybe have broken some plaque loose and stuck an injector?The only other main change is the heat here has risen to upper 90's w/70-95% humidity(heat index of 102-108).Would the high heat and humidity do this?
Last tank I reset the ecu,filled up with Chevron gas ,and added a bottle of injector cleaner (hoping to finish the job),yielding 33.6 again.
I would really like to avoid this again ,so any explainations or suggestions would be welcome.
The SRI should not have adverse effects since the throttle body is still the same,and the muffler should have helped if anything,since the piping remained the same there is no chance of over scavanging.
:whistling:
fonque
post Aug 8 2008, 02:49 PM
Drives: 08 accent
does our accent use side feed or top feed injectors?
Side feed injectors are notorious for being clogged/damaged by off the shelf injector cleaner.
...I really need to purchase the factory service manual.
HMAservice is just not cutting it.
Komptek
post Aug 8 2008, 03:05 PM
AMSOIL T1 Direct Dealer
Drives: '07 Accent SR, '08 Santa Fe Limited
Injector clears do improve MPG, but you need to follow in instructions.
1. On fill up put in injector cleaner.
2. Run tank to near empty.
3. Fill up tank.
Now you should see the gains, you won't see them during, because your cleaning the injectors.
themike84
post Aug 8 2008, 03:59 PM
Drives: 07 Accent SE
QUOTE(fonque @ Aug 8 2008, 02:49 PM)
[right][snapback]181738[/snapback][/right]
I heard these cleaners are bad for your engine...if there are some that do this...which ones are good?
Komptek
post Aug 8 2008, 05:39 PM
AMSOIL P.I. has a money back warrantee and chart showing that it works.
Tango2Go
post Aug 8 2008, 09:27 PM
I used STP the first time and the mileage dipped and stayed this last time I think it was Chevron brand.
I do know their gasoline w/Techron gets better mileage than most any other I have used and does so consistantly.
Thanks for the imput. :thumbsup: :liebe011:
This post has been edited by Tango2Go: Aug 8 2008, 09:28 PM
hoosieraccent
post Aug 8 2008, 09:51 PM
Status: Online
Drives: 06 accent
Mine always ran smoother, had more pep, and better FE on Chevron. Pitty they all closed up shop in my neck of the woods. :|
I do throw in a bottle of Techron, and usually see a slight decrease in FE for that tank. Once it's worked its way through the system though, it goes back up.
themike84
post Aug 9 2008, 10:05 AM
besides amsoil, any other ones people recommend?
hyunnychub
post Aug 13 2008, 10:10 PM
Drives: 2007 Accent 3 door 5 speed
I use mostly Wyyns fuel injector cleaner, sometimes if its not available i use bhardal brand..
No New Posts After Market Shocks
Discussing Replacements
12 snaglepus 224 19th November 2008 - 11:44 PM
Last post by: budh
No New Posts Topic has attachmentsAnyone Want A Set Of Autolight Extremes? Spark Plugs
6 v33sonata 102 11th November 2008 - 02:35 PM
Last post by: v33sonata
No New Posts Anyone Tell Me How To Position My Headlights?
cant find it on the forum :S
5 AFireryAccent 116 29th October 2008 - 09:47 AM
Last post by: rondy_
No New Posts Anyone Using Synthetic Oil?
true synthetic, like Mobil 1
4 jayselantra2 162 26th October 2008 - 10:38 AM
Last post by: EdGasket
No New Posts Have Oem Azera Grill Available
Check Classifieds
2 david-paul-1 216 12th October 2008 - 11:23 PM
Last post by: david-paul-1
23rd November 2008 - 02:59 PM
