QUOTE(nevis111 @ Aug 8 2008, 12:39 PM)
What MPG were you acheiving prior to shifting to synthetic oil?
[right][snapback]181731[/snapback][/right]
:laughing: Man that was a long time and many miles ago. I switched in November, 2006 right around the same time the idiots made 10% ethanol blended gasoline mandatory in Oregon. So I didn't see that much of an increase. I think I went from averaging 18.5 to getting 19.5 to 20. Not drastic but a change never the less.
However....I will frequently go up to Washington for my gas as they use a less-than-10% ethanol blend and I consistently get better mileage on WA gasoline; I usually average 22 mpg on a mixed Washington tank.
Also, I drove through Utah in June and they do not use ethanol there at all. I got 26 mpg on almost all-highway (did putt around SLC for a bit).
I'm sure that's more than you were bargaining for but there it is. :whistling:
