> Coolant Overheating At High Speeds While Ac Is On
Atti_5
post Aug 5 2008, 05:49 AM
Drives: Hyundai Accent Elegance 1,3 12V SOHC 62kW, Model 2005
Having my first technical issue with my 3,5 years old Hyundai Accent.
During past years the engine coolant temperature gauge was - after warming up - always pointing to the middle of the scale (inbetween the two small dots). This was not depending on vehicle speed or outside temperature.
Since a few weeks I experience following problem:
The gauge is showing higher temperatures, between the middle of the scale and the red zone, but never reaches red zone.
This happens only at higher speeds, over 100 km/h (60 mph). When the problem happened, the temperature was about 30 degrees C (86 degrees F).
It only happens, when AC is switched on!
Even with AC ON, the gauge is pointing to the middle when the speed is at about or below 90km/h (50 mph), so I only experience this on highway.
While having AC off, the coolant is not heating at all = gauge pointing to middle at very high sppeds and uphill - 140 km/h (82 mph). :)
I did following troubleshooting/checks already:
- cleaned the both radiators from insecpts, washed.
- both fans works OK.
- fan belt of coolant pump is OK.
- coolant level is full, and NOT loosing any coolant.
- oil level also OK.
Could you please advice two things please:
- what can be causing above issue?
- how critical is it to run engine with slightly high coolant temperature (over middle of scale, but below red zone)?
Thanks, Attila
Lucid484
post Aug 5 2008, 08:38 AM
Drives: 2005 Hyundai Accent GLS
you could try flushing and adding new cooland....could also be a couple of other things.
-Air Trapped in the system
-Water pump or one of the passages could be slightly clogged
-belt on the pump or maybe the pumps pully is slipping
-could be a bad thermostat
and maybe a couple other things.
I would not constantly run above normaltemperature....the reason why my wife got a accent was because we were driving in her old car and her temp kept going up...we kept shutting down the engine and it never went in red....but there was a crack in the block which ruined the whole engine. it was a bad water pump.
TommyR
post Aug 5 2008, 09:52 AM
Drives: Hyundai Accent 2000 1.5L SOHC, Manual, no A/C, 50K mileage
Years ago that was a symptom of a lower coolant hose, suction, collapsing do to high speed. That hose had metal spring in it to prevent it from happening.
-tr
bowsercake
post Aug 5 2008, 02:58 PM
Drives: 1990 Toyota Supra Turbo
A quick way to remove air from the system to to jack up the front of the car or park on an inclined driveway and run the car with the radiator cap off. Don't take the cap off if you have driven the car recently because you will get burned by steam. After the car has been warmed up fill the radiator up to the top with distilled water or a coolant mixture.
If that doesn't help you might have a bad water pump that can't flow enough at higher speeds. Also check your radiator hoses for pressure.
Atti_5
post Aug 11 2008, 08:07 AM
Thanks for the tips and ideas - I decided to have it checked at hyundai official service, rather than dealing with it by my own. This wednesday I will know more:)
Kind wishes, attila
rancal
post Aug 14 2008, 08:16 PM
Drives: 2006 Chevy Tahoe 2006 Hyundai Accent
Try looking at the engine coolant temp senor. May be defective. Ac is turning on fans but is the actual cooling system (coolant) is turning on the fans at correct temperature.
No New Posts Higher Mileage Accent On The Way
"Accent Blue"
4 hoosieraccent 38 Today, 02:41 PM
Last post by: liquid_02
No New Posts Coolant Reservoir Question
4 John_ 41 Today, 11:40 AM
Last post by: montego
No New Posts Attention: I30ownersclub Members
Important information/request
21 dazzling_darryl 825 21st November 2008 - 03:07 AM
Last post by: Shambles
No New Posts Is This Right?!
Oil Change Service
2 jlien222 17 17th November 2008 - 10:30 PM
Last post by: jlien222
8 cantfoolthewise 129 17th November 2008 - 11:11 AM
Last post by: cantfoolthewise
23rd November 2008 - 02:51 PM
