QUOTE(Bizzenn @ Aug 4 2008, 10:21 PM)
does anyone know what the best product is to clean the cloth seats on the 07 Santa Fe? I'm just not sure due to the type of cloth.
[right][snapback]180882[/snapback][/right]
The cloth seats in your Santa Fe are no different than any othre vehicle, or piece of furniture, for that matter.
Normal upholstery cleaner will work. They are found in most grocery stores. I have used the spray type foam for spot cleaning and liguid types that come in concentrates.
Woollite is a spray that comes to mind. Most of the concentrates are the same.
Just make sure when using the concentrates, that you use the suds that you work up, as opposed to saturating with the liquid beneath.
David <><
