> Gen 3 Part Numbers
Unfated
post Aug 3 2008, 01:09 PM
Status: Online
Drives: 2008 Hyundai Accent GS 3-Door
Air Intake (AEM SRI):
Blue: U8970-1E310
Silver: U8970-1E300
Oil Filler Cap: U8972-1E000
OEM Oil Filter: 26300-35503
OEM long life fuel filter: 31112-1G500
Oil plug gasket/transaxle plug gasket: 21513-23001 (Lots of 10 I think)
OEM spark plugs: 18814-11051 (BKR5ES-11) (non-platinum)
OEM PCV Valve: 26740-26700
OEM Cabin Air Filter: 08790-1E000-A
WIX Cabin Filter: 24484
OEM Air filter: 28113-1G000
K&N Air filter: 33-2354
OEM Ignition key blank: 81996-1E000
iPod/Cellphone Holder: U8790-1E00
This post has been edited by Unfated: Aug 5 2008, 02:06 PM
Komptek
post Aug 3 2008, 05:53 PM
AMSOIL T1 Direct Dealer
Drives: '07 Accent SR, '08 Santa Fe Limited
2007 HYUNDAI ACCENT 1.6L 4-cyl Engine Code [C] DOHC
AMSOIL & WIX PARTS LIST
FILTERS
Absolute Efficiency Oil Filter: EAO20
WIX Oil Filter: 51334
WIX Air Filter: 49069
TRICO WIPER BLADES
Blade Class Driver and Passenger
NEOFORM T16220 T16160
EXACTFIT T221 T161
WINTER T37225 T37160
OKTANE 22 inch 16 inch
LUBRICANTS & FLUIDS
Engine Oil Grade 1......API*
100% Synthetic 0W-20 Motor Oil
SAE 5W-20 XL Synthetic Motor Oil
SAE 0W-30 Synthetic Signature Series Oil
Manual Transmission,.....GL-4 75W-85
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Automatic Transmission.....SLF[1]
Synthetic Automatic Transmission Fluid
Fluids
Brake Fluid.....HB
Series 500 High Performance DOT 3 Brake Fluid
Clutch Fluid.....HB
1. SLF is Hyundai SP-III Automatic transmission fluid
CAPACITIES
Engine, with filter..........3.3 liters[1]
Cooling System, W/ AT Initial Fill..........5.4 liters
AMSOIL Antifreeze and Engine Coolant
Cooling System, W/ MT Initial Fill..........5.8 liters
Automatic Transmission, Total Fill..........6.1 liters
Manual Transmission, ..........1.9 liters
1. After refill check oil level.
TORQUES
Oil Drain Plug.....29-32 ft-lbs
Manual Transmission
Fill Plug.....43-58 ft-lbs
Drain Plug.....43-58 ft-lbs
This post has been edited by Komptek: Aug 3 2008, 05:54 PM
LilBean
post Aug 3 2008, 08:57 PM
Expert
Actually, a couple part numbers are incorrect. Here are the correct numbers:
OEM oil filter
26300-35503
OEM cabin filter
08790-1E000-A
Along with a couple other maintenance items:
31112-1G500
OEM spark plugs
If you can think of any other numbers that would be good to add, just ask.
hoosieraccent
post Aug 3 2008, 09:21 PM
Status: Online
Drives: 06 accent
I think that cabin filter # above came from me. Looking at the filter selections, I see Hyundai did make a change midyear in 2007 for the cabin air filter part number. Wix also shows 2 different filters for a 2006 and a 2007+.
Unfated
post Aug 4 2008, 08:48 AM
Status: Online
We could use all the part numbers you want to list. I'm trying to get a good list
and get it stuck (sticky).
LilBean
post Aug 4 2008, 09:16 AM
Expert
Well, being as I have access to ALL the part numbers for the car, you're gonna have to be a lil more specific... lol
WeirdGermanAccen...
post Aug 5 2008, 05:56 PM
Drives: 08 Accent GS 3Door
I'd be interested in the factory part number for the Eibach springs... if that is even an option here in the states.
LilBean
post Aug 6 2008, 05:33 AM
Expert
Sorry, its not a US option, nor is it even a US accessory from Hyundai. You'd have to buy them straight from Eibach.
Komptek
post Aug 6 2008, 07:40 AM
QUOTE(WeirdGermanAccent @ Aug 5 2008, 04:56 PM)
[right][snapback]181032[/snapback][/right]
Numbers off the springs are
194713
007BL10105R
194712
007BL10105F
I can't remember which is the front or rear but those were the numbers off the springs.
WeirdGermanAccen...
post Aug 6 2008, 03:01 PM
Thanks Komptek. Shame we can't get these from the dealer here in the states... I'd love to have lowering springs with a factory part number. I guess I'll just have to go the aftermarket route.
No New Posts Topic has attachmentsGenesis Wheels
6 brihvac 77 Yesterday, 02:52 PM
Last post by: ironman
No New Posts Parting Out 2006 Huyndai Azera "new & Used"
Engine Parts New in Box and used Azera
0 4jrfox 8 29th November 2008 - 10:39 PM
Last post by: 4jrfox
No New Posts Genesis To Appear In Fast & Furious 4
4 madderhatter 763 24th November 2008 - 11:03 PM
Last post by: hugamuto
No New Posts Genesis Marketing?!
Same Mistakes all over
13 Pelikan 271 24th November 2008 - 12:41 AM
Last post by: Cyric
No New Posts Genesis Wing Emblem Installation Process
11 jwaters943 1,268 23rd November 2008 - 12:57 PM
Last post by: EF/ELP
2nd December 2008 - 10:12 PM
