> 1994 Excel Horn Problem
Conundrum
post Aug 3 2008, 11:12 AM
Drives: 1994 Excel
Hello,
Got some problem with my 1994 Excel's horn. The horn would not stop beeping, can any one help with the diagnoses?
Thank you.
joecamel
post Aug 4 2008, 03:40 PM
Drives: Hyundai Tech
unplug it does it stop? get new horn button installed ok now? stop hitting horn button so hard.
Conundrum
post Aug 4 2008, 07:13 PM
Drives: 1994 Excel
Bought it used, never check the fuse, so I never knew the horn did not work. If fuse is pulled, it stops, if fuse is replaced, it keeps beeping.
Question though... where is the horn button? Is it part of airbag assembly or steering? How do I get to it?
Thank you.
This post has been edited by Conundrum: Aug 4 2008, 07:14 PM
frugle93
post Jan 18 2009, 10:47 PM
Drives: 1993 Hyundai Excel 1.5L
I had the exact same problem. Bought a used 93 Excel, and the horn was "stuck" on. I used a multimeter to find that the problem originated from the horn button (in the centre of the steering wheel). The foam which keeps the contacts apart had degraded, which let the contacts keep touching one another after the horn had been released. You could simply replace the centre of the steering wheel, though this would be a fairly short term fix, as the foam in the new switch would eventually degrade too. Or you could do something like what I have done, though it is sort of fiddly and consumes a fair amount of time. I removed the horn button from the steering wheel, pulled the vinyl off it, then popped the brassy coloured peices of metal from it. These peices of metal, with the foam in between is the horn switch, pull the metal peices apart, scrape off the old foam and replace. I used a mouse pad! Simply cut the outside edge of the foam to match the shape of the two metal peices, the mark and remove material (in the same pattern the factory did) so that the raised parts of one plate can touch the other... Then put it all back together. Hope this helps, if you got any further questions on this topic, post them and I will explain further.
No New Posts Problems With Wifes Car
0 WifesWhiteTiburon 12 Yesterday, 11:10 AM
Last post by: WifesWhiteTiburon
No New Posts Problem With Attached Files
7 burnitwithfire 48 13th March 2010 - 11:46 AM
Last post by: burnitwithfire
No New Posts 1994 Toyota Supra Vs. 1993 Mazda Rx7
11 tork 9,285 12th March 2010 - 09:05 PM
Last post by: kurtdaniel
No New Posts Problems With 2003 Sonata V6
3 surfguy17 64 9th March 2010 - 10:52 PM
Last post by: surfguy17
No New Posts Topic has attachmentsProblem Pairing Cell Phone 2010 Tucson
samsung alias 2 won't pair with on board bluetooth
8 Bill J. 319 9th March 2010 - 08:43 AM
Last post by: Alan P
20th March 2010 - 04:18 AM
Privacy Statement
