Coolant By-pass Mod Diy |
Jul 31 2008, 09:42 PM
AMSOIL T1 Direct Dealer
Status:
Drives: '07 Accent SR, '08 Santa Fe Limited
OK tools needed first. 10mm wrench gripping pliars Ok this mod is to help reduce the air temp going into the intake manifold. Not sure why Hyundai even has this little by-pass happening since all it does it heat up the intake manifold and causes warmer air in the engine. As for you guys up in Canada don't be afriad of the low temps in winter. I ran all winter without any issues, but it is easy enough to reverse for winter if you wish. Ok as you can see this is from the rear of the motor looking up toward the intake throttle body. The bypass in question is the two tubes labeled A. Steps: 1) Remove the top tube completely first. 2) Disconnect the lower tube at the throttle body only. 3) Reattach the end of that tube to where you removed the first tube from the motor. Ok your done, well almost. 4) Take that 10mm wrench and reset your ECU by diconnecting the battery. OK now your done. enjoy!
This post has been edited by Komptek: Jul 31 2008, 09:42 PM
Aug 2 2008, 07:45 AM
Expert
Status:
Drives: 2008 Accent GS, 1.6
QUOTE(hoosieraccent @ Aug 1 2008, 08:28 AM) Warmer air flowing through the intake is better for fuel economy, so they may have done it for that reason... You get less power with tle less dense warmer air and use less fuel, colder air gives you more power at the expense of more fuel. A lot of the hypermiler guys have been setting up warm air intakes. :thumbsup: [right][snapback]180151[/snapback][/right]
think maybe they did this as another place to dissapate heat? seeings how our radiators are the size of a postage stamp and thin as one too! with my SRI and big exhaust, ive noticed the when my engine is hot like after my drive home from work (scan guage reads between 188F and 194F) that my exhaust is much louder and deeper in tone.... not complaining, i think it cool! but im thinking it also has something to do with the hot engine..... i guess.... :whistling:
