 Hyundai-Forums.com > Hyundai Models > Scoupe Forum
> Dump Valve, Should I get a Recirc valve?
aj7
post Jul 31 2008, 10:09 AM
Drives: Hyundai S Coupe mvti (94)
Hey Guys/Gals,
I currently have a Bailey DV26 Dump valve fitted to my car...and it sounds lovely :grin:
I've read somewhere that I should have fitted a DV30 as it recircultes the air, to up the performance of my car. IS this true? :puzzled:
I've looked around and it looks like the DV30 is specific to certain models of car.
Is there a fitting kit for the DV30? If so, where?
Am I safe using a DV26 Dump Valve without damaging the engine or should I get a DV30?
Thanks.
eyelid
post Jul 31 2008, 11:10 AM
Drives: Scoupe GT '94
If you have dump to athmosphere -valve, the ECU doesn't know that the air has dumped away because it's monitored trough your MAF (hot wire unit), that's why you should have recirculating valve which pushes the air back to turbos intake side and ECU can get the correct values from MAF.
Was it complicated enough to explain? :D :D
aj7
post Jul 31 2008, 01:18 PM
thanks eyelid.
Ok i can get the DV30 but is a kit supplied with it? Can you buy a fitting kit for them?
Oh and wheres the best place to install the kit. Between the MAF and the turbo?
Cheers
VALKYRIE YB70
post Aug 2 2008, 11:42 AM
Mod Emeritus
Drives: Modified (180 b.h.p.) `95 Hyundai S-Coupe Turbo SE ....Sadly now sold & replaced with an `04 Alfa Romeo 156 2-litre Veloce! :-http://aol.photobox.co.uk/album/thumbnails.html?c_album=7089276&page=all
Hi!
The DV 26 is fine for your car as it is a twin-piston design & does not create the `bogging-down` effect of a normal vent-to-atmos. BOV.
The Bailey DV 30 re-circulating dump valve is slightly more efficient on the S-Coupe Turbo, but you lose most of the sound & you will need to run a hose from it`s outlet into the main intake pipe (between the MAF & the turbo).....sealing the joint with black silicone sealant (or even underseal).
Just make slits in the main pipe like * & push the vent-hose inside 1/2" or so.
Cheers,
Nick. :)
eyelid
post Aug 3 2008, 03:50 PM
It's not bad losing most of the sound, with these kind of cars it's better to be a little bit of stealth.
Like it that way. :)
aj7
post Aug 4 2008, 08:02 AM
Thanks guys!
:banana:
No New Posts Valve Cover Leak
3 Aubieky 281 21st October 2008 - 12:24 AM
Last post by: crackedlens
No New Posts Topic has attachmentsValve Cover Gasket Change
help a guy out
4 dxddanilo 1,087 3rd September 2008 - 08:35 PM
Last post by: adkinsbl
No New Posts Valve Clearances
what is the valve clearances
1 S COUPE TURBO 346 24th July 2008 - 11:11 AM
Last post by: VALKYRIE YB70
No New Posts Valve Spaces?
any body knows how many mm is the valve
0 nadewf 70 10th May 2008 - 01:37 AM
Last post by: nadewf
No New Posts Valve Body Pics? For 93 Excel
0 joesnextoy 417 2nd April 2008 - 08:12 PM
Last post by: joesnextoy
2nd December 2008 - 09:31 PM
