:beer:
"smichelsen"
Are both side having the same problem? If not, ensure that the parking brake lever in the car is in the down (off) position, and remove the other drum only if it comes off easilly, DO NOT pry the other drum off. If the above works, compare both side and see if the problem side need some adjustment. If the above fails, go on with the remaining explanations,,, As per the picture you supplied.... First; with the parking brake lever in the car in the down(off) position, check the shoe return upper spring, it should not be extended at all, it should not be under tension at all. Second; with the parking brake lever in the car in the down(off) position, ensure that the operating lever as completely returned back to its normal position which is right behind the brake shoe. Third; if step 1 and 2 are corrected, check to see if the drum will fit, if not, notice where it dosen't fit...Is it at the top of the drum or the bottom? Let me know... If it's the top of the drum that will not fit, the brake shoe adjuster will need adjustement. If it's the bottom of the drum that will not fit, the brake shoes are not position properly on the baking plate. Awaiting your response for further instructions. :amen:
TheIceAge
:beer:
