I own a 2002 Hyundai Santa Fe AWD with a 2.7L V6. The car has approximately 91,300 miles. (The warranty is no longer valid since I am not the original owner.) I just had the timing belt and timing belt tensioner replaced. When I picked the car up, there was a new metallic-sounding clocking noise present that was not there before. It is proportional to engine speed (i.e. - it is more rapid at high RPMs) and does NOT go away once the engine has warmed up to normal operating temperature. I drove the car for several days and a few hundred miles, and it seems to operate normally (oil pressure and engine temperature are OK, and gas mileage is the same as normal). It just has this annoying metallic-sounding clocking noise.
I took the car back to find out what this noise was, and the service shop (which is part of a Hyundai dealer) claimed that the noise was due to a faulty sepertine belt tensioner. This sounded suspicious, but since they do have to pull off the serpentine belt to replace the timing belt, I agreed. (They only charged me for the sepertine belt tensioner itself, not the labor.)
When I picked up the car, the noise was still there! I told them that they hadn't fixed the problem, so they looked at it again and now they say that the lifters are bad and it will cost about $600 to replace them. (Oh, and they say the noise is different now and they will not refund the money for the serpentine belt tensioner.)
Clearly, this dealer did something wrong to cause this noise, and now they are jerking me around to a.) cover their butts, and b.) see how much money they can get out of me.
Any idea on what this metallic-sounding clocking noise could be? And is it possible (and even probable) that it was caused by faulty work in replacing the timing belt and timing belt tensioner?
