> Help Ecu And Rear License Bulb
mrblank
post Jul 28 2008, 04:13 PM
Drives: 2008 3DR Accent
i was wondering when everyone was saying it need a bracket for ECU when installing SRI is that it
So is it that silver thingy feel free to draw on it
Also i was changing bulbs again this time i hit a wall anyone know how to access it cause my screw driver wont fit in there
o ya today i saw a Dodge challenger today
Attached File(s)
LilBean
post Jul 28 2008, 05:05 PM
Expert
Yes the ECU is the "silver thing" lol. It is mounted to a bracket that is also the bracket that bolts to the bottom of the airbox and holds the airbox in place as well.
As for the license plate lights, I have no idea, I've never even looked at it.
Nice Challenger, but it's still a Dodge. :unsure:
themike84
post Jul 28 2008, 05:27 PM
Drives: 07 Accent SE
QUOTE(LilBean @ Jul 28 2008, 05:05 PM)
[right][snapback]179427[/snapback][/right]
we got two down here, black and nice looking orange...still waiting for the Camaro... and i would do a search for custom intakes so you can see what people that made a custom bracket used...i just left the OEM box on and i was still able to close my hood...lol
bloodninja
post Jul 28 2008, 08:50 PM
Expert
Status: Online
QUOTE(mrblank @ Jul 28 2008, 04:13 PM)
[right][snapback]179418[/snapback][/right]
Hey man, I'm wondering the same thing. I have LEDs galore from my previous car and I wanna transfer my HID White LEDs to my license plate, but I can't figure out how to get those **** screws out lol
r4square
post Jul 29 2008, 01:17 AM
Drives: 2007 Accent Sport Hatchback
I got to the rear license plate bulbs by removing the rear interior panel on the hatchback. After the panel is removed you reach your arm through the access holes and rotate each bulb socket and pull it out.
To remove the panel, remove all the screws and then pull the panel off releasing it from clips. Be careful not to stress the plactic too much to you may suffer breakage.
bloodninja
post Jul 29 2008, 01:32 AM
Expert
Status: Online
QUOTE(r4square @ Jul 29 2008, 01:17 AM)
[right][snapback]179507[/snapback][/right]
cool, thanks. yeah, I tried removing the screws, but i was afraid of breaking off the plastic because it was putting up fierce resistance to pulling haha. I'll give it a second try.
r4square
post Jul 29 2008, 03:05 AM
just work your way around the panel. I started at the side and worked my way around the bottom. I do recall finding the clips on the top half more difficult to release.
TroyHansen
post Jul 29 2008, 05:19 AM
Drives: 08 Hyundai Accent SE 5-spd
I wanted to change out a few bulbs too, like the blinkers to make them less yellow, can we use any bulb as long as it's the same size?
o0kat0o
post Jul 29 2008, 10:39 AM
Drives: 2007 Hyundai Accent SE 3 door hatchback
Accent Bulb sizes
This gives most of the bulb sizes out car needs.
bloodninja
post Jul 29 2008, 03:07 PM
Expert
Status: Online
QUOTE(TroyHansen @ Jul 29 2008, 06:19 AM)
[right][snapback]179527[/snapback][/right]
You can, BUT if you don't use the 2357 or whatever, and you opt to use a 1157, it WILL work, BUT it will not be as bright because they use different amperages. They will however function properly, they just won't be as bright if you don't use the proper bulb type. Trust me, I tried it yesterday.
Oh, and also... I installed my HID White LED license plate lights today (transferred from 98 prizm without a hitch, though they are HARD AS **** to get your fingers around, even with smallish fingers). Will take a pic later this evening as it gets dark.
This post has been edited by bloodninja: Jul 31 2008, 06:09 AM
mrblank
post Jul 29 2008, 10:07 PM
Post #11
QUOTE(bloodninja @ Jul 29 2008, 03:07 PM)
You can, BUT if you don't use the 3157 or whatever, and you opt to use a 1157, it WILL work, BUT it will not be as bright because they use different amperages. They will however function properly, they just won't be as bright if you don't use the proper bulb type. Trust me, I tried it yesterday.
[right][snapback]179610[/snapback][/right]
HID??? WHite Led? do you mean Bright White led cause if you had HID you need a ballast for your rear license plate light and that is just a bit over kill
mrblank
post Jul 29 2008, 10:08 PM
Post #12
QUOTE(r4square @ Jul 29 2008, 03:05 AM)
[right][snapback]179520[/snapback][/right]
So you have to open the hatch and unbolt and unclip the pannel and unscrew the tail gate cover so you can have access to the License bulb
rondy_
post Jul 29 2008, 11:48 PM
Post #13
Drives: 2006 Hyundai Accent
QUOTE(mrblank @ Jul 29 2008, 10:07 PM)
[right][snapback]179681[/snapback][/right]
when he says HID white led he means the HID color, not actual HID
bloodninja
post Jul 30 2008, 03:45 AM
Post #14
Expert
Status: Online
QUOTE(rondy_ @ Jul 30 2008, 12:48 AM)
[right][snapback]179690[/snapback][/right]
Right you are, thank you for the clarification :)
ALSO, if any of you are in the market for LEDs for your car, please check out V-LEDS.com. That's where I have gotten all the LEDs for my car and they are VERY high quality. Expensive, but well worth it!
As promised, here's the picture of my license plate HID White LEDs from V-LEDS.com...
This post has been edited by bloodninja: Jul 30 2008, 03:46 AM
Attached File(s)
mrblank
post Jul 30 2008, 03:46 AM
Post #15
QUOTE(bloodninja @ Jul 30 2008, 03:45 AM)
[right][snapback]179706[/snapback][/right]
i got mine from ebay for 12 dollar after shippping now is sitting on my dash board cause i cant figure how to put it in
bloodninja
post Jul 30 2008, 03:53 AM
Post #16
Expert
Status: Online
Follow Mr Blank's directions and you should have no trouble... to summarize, unscrew the 4 phillips head screws from the inside of the hatch door. then, starting on either side, CAREFULLY pull gently until you hear/feel a pop, then continue popping it out until you have removed the plastic panel.
The hardest part is getting the **** light sockets out from behind all the metal crap. HINT: you have to twist them CLOCKWISE to get them out, and COUNTER-CLOCKWISE to put them back in... that took me forever to figure out since it's the opposite of American standards.
Then carefully line up the plastic piece again once youve replaced the lights (and made sure they work before putting them back into place) and snap it back into place. Put the screws back in the panel and VOILA, your car looks HOT.
mrblank
post Jul 30 2008, 04:29 AM
Post #17
QUOTE(bloodninja @ Jul 30 2008, 03:53 AM)
[right][snapback]179710[/snapback][/right]
Yes i have good directions the problem is action XD
bloodninja
