Hi folks.
I'm having a problem with my 94 Excel. When I come to a stop the vehicle shudders and acts like it's going to stall but doesn't quite. If I take my foot off the brake and re-apply the brake it's fine again and idles fine. Recently changed the plugs, thermostat and front brakes. The problem coincided with a grinding noise in the right front which resulted in me getting the new brakes. Had mechanic also look into the above problem and he said he thought it might be the brake booster but wasn't sure. He checked the TPS and came to the conclusion that this wasn't the problem. Before I give the go ahead to start changing out parts in a random attempt to try and fix this problem I'd like to get your suggestions.
Thanks in advance.
Mark
This post has been edited by snipe: Jul 28 2008, 04:39 PM
