Dear audio,
Are you still under warranty, and I mean the 80,000 mile emissions parts warranty? Yes, you have something desperately wrong. The front converter running hot simply means you have too much unburned/incompletely burned fuel traveling to the front converter, where the converter is desperately trying to burn this to CO2 and water vapor.
Have you had Check Engine Lights (CEL)on for months? Your O2 sensors will trip a CEL code for nearly any malfunction. If you don't have a CEL, get your car's ECU log read at a dealer. This will give you a historical record of the different faults on your car.
Maybe you burned out the CEL light. (Don't laugh...my ex-wife burned out the low-fuel light on a Honda Accord because the light was on for months at a time)
Does your CEL light come on during the self-test function upon ignition start?
Byron
