G'day all, my dad has a 2003 Hyundai Getz 1.5L and its running really harsh. When started in the mornings the car will have a very harsh rumbling and vibrations throughout the hole car! So much so that you can see the steering wheel shake. This hangs around for about an hour until the car seems to warm up abit and then, as if someone flicks a switch, it returns back to its normal state of running really smooth and quiet! I've done the obvious oil change and injector clean, plus changed the plugs leads and coil pack and still thing the same thing happens. Just wondering if anyone has had this problem or if anyone might have any ideas to what it could be and how to fix. The only thing i have come up with is that the engine mounts may be very stiff until they heat up abit but i could be way off.
Would appreciate anyone's thoughts and ideas! thanks guys!
Phill
