Thanks doohickie, fortunately I decided to check the AM radio reception issue first and removed the dash facia IAW the instruction on the "DIY" pages. After removing the radio fully and wrapping the foil around the support bracket, I replaced the audio unit, re entered the security code and "TaaDaa" :clap: the error had disappeared. Obviously removing the power to the unit has reset the offending part and now works well. The AM noise problem is 90% rectified also, just need to get the inline filter onto the arial cable to be able to listen to the football whilst driving now.
