> Replacing Rear License Plate Frame, I thought this should be easy.
bakshi6
post Jul 19 2008, 11:33 AM
Drives: 2007 Hyundai Sonata Limited Platinum
I'm in the process of removing all dealer badges, including the two plate frames (front/rear). The front one was replaced rather easily. The rear plate has one screw (the left screw) which refuses to come out. It can be turned clockwise or counterclockwise, it just doesn't unscrew at all. The right screw came out rather easily. I wanted to inspect the other side of trunk, to SEE what the issue was, so I removed most of the Trunk lid trim from the inside of the trunk. I got most of it removed, except for the "handle" which didn't budge and I wasn't about to damage my car just to remove a plate frame. I found a square cut into the metal, I couldn't see into because the handle part of the inner cover was still intact. I felt a plastic piece which this screw is inserted into. But this didn't help me much (it was fun pulling the car apart though, something I rarely do).
Umm, can anyone help me? What can I do to get this screw removed? I'd love to trash the dealer frame. :banana:
Thnx.
This post has been edited by bakshi6: Jul 19 2008, 02:22 PM
morrjr
post Jul 19 2008, 12:20 PM
Drives: 2009 Hyundai Sonata GLS 2.4
If you can grab the head of the screw with Vise Grips or pliers, CAREFULLY grab the head of the screw and turn counterclockwise while pulling out slightly at the same time. Slight pressure while turning the screw should be all you need to allow the screw to back out without damaging the insert that the screw goes into.
craigbrooks
post Jul 19 2008, 01:04 PM
Just hangin' out...
Drives: 2006 Hyundai Sonata GLS F24S (DOB 04/30/05), 1997 Mustang V6 Convertible
when you get the screw out go and buy new inserts. Trust me you will need and want to replace it. My left one went bad so I replaced it. I wished I would have replaced the right at the same time. It is spinning inside now. Any parts store carries these as they are generic.
LevelThree
post Jul 19 2008, 01:49 PM
Drives: 2006 Hyundai Sonata V33, 1994 BMW 325ic
FYI, to remove the handle and get the trunk trim off, all you have to do is unscrew a single phillips head screw up inside the handle. I learned this the hard way.
bakshi6
post Jul 19 2008, 06:20 PM
Okay, I did that, removed the entire trunk trim (ty LevelThree), and held the plastic insert while I unscrewed the stuck screw, came out easily, but I couldn't find the inserts at "advance auto parts" so I'll have to check around. Would like to replace both the rusty screws and those inserts. :460:
Thnx all.
This post has been edited by bakshi6: Jul 19 2008, 06:21 PM
SonataRobbie
post Jul 24 2008, 04:11 AM
Jack of All Trades; Master of None
Status: Online
Drives: 2006 Hyundai Sonata GLS 3.3L V6 (DOB 11/08/05)
QUOTE(bakshi6 @ Jul 19 2008, 05:20 PM)
Thnx all.
[right][snapback]177282[/snapback][/right]
Same thing happened to me. My dealer parts department gave me two new inserts to use. They had a huge bin of them. Give your dealer a try. Worst case: they charge you a couple bucks. Either way, your problem will be solved.
MABuch131
post Jul 24 2008, 09:19 AM
Drives: 2006 Hyundai Sonata GLS V6
same thing happened to me, took it into the dealer and they fixed it for free in less than 15 min with no questions asked.
craigbrooks
post Jul 24 2008, 10:47 AM
Just hangin' out...
Thnx all.
I just yanked mine out with vise grips and put new plugs in. Very easy.
No New Posts Replacing Cigarette Lighter?
1 pnavid 183 Today, 03:35 AM
Last post by: 2002accent32
No new Topic has attachmentsRear High Bulb Replace - Ahhhh
26 playadave 707 20th November 2008 - 06:29 AM
Last post by: ddix1026
No New Posts Replacing Catylictic Converter
0 nmguy 9 18th November 2008 - 03:29 PM
Last post by: nmguy
No New Posts Rear Window Winder
1 akita1 85 7th November 2008 - 12:54 PM
Last post by: montego
No New Posts Rear Deck / Parcel Tray Rattle W/factory Sub
New Info, dealer to replace and rebuild!
8 nrfx 468 7th November 2008 - 07:57 AM
Last post by: TypeSDriver
22nd November 2008 - 04:54 PM
