Hi folks,
I wonder if any of you can advise? I have a late 2006 Santa Fe (2007 model). It's a great car but I have one niggle that Hyundai seem loathe to help me with. Cruise Control cuts out on its own in particular circumstances. It's been in to the service centre six times and I'm now told that Hyundai UK say "that's the way it should be." Is it me, or am I correct? Hyundai have quoted page 104 to me (see below), but surely that's only if the speed DECREASES more than 9mph BELOW the set speed. I'm not going below the set speed, I'm exceeding it. I'll set the scene...
If I am following a vehicle with cruise control on, at, say, a steady 60 mph, and I want to overtake a vehicle, I depress the accelerator to gain speed, overtake the vehicle, and then pull in and release the accelerator pedal. The instructions and
every other car I’ve ever driven with cruise control follows this pattern, the speed should drop back down to 60mph and then continue at that speed. The fault on my vehicle is that when I get to around 5-7mph over the ’set’ speed, the SET light extinguishes on the dashboard, cruise control function ceases, and the speed drops back to zero, if left. This is patently wrong.
The Santa Fe manual states:
P103: To increase speed, temporarily depress the accelerator pedal enough for the vehicle to exceed the preset speed. When you remove your foot from the accelerator pedal, the vehicle will return to the speed you have set.
P104: NOTE: If the vehicle speed decreases more than 9 mph (15 km/h) below the set speed or decreases below 25 mph (40 km/h), the cruise control system will automatically cancel the set speed.
Even Wikipedia agrees with my understanding:
Quote from Wikipedia: Cruise Control
...The car will maintain that speed by pulling the throttle cable with a solenoid or a vacuum driven servomechanism. Most systems can be turned off both explicitly and automatically, when the driver hits the brake or clutch. Cruise control often includes a memory feature to resume the set speed after braking and a coast feature to reset the speed lower without braking.
When the cruise control is in effect, the throttle can still be used to accelerate the car, but once it is released the car will then slow down until it reaches the previously set speed. Source
Wikipedia - Cruise ControlHas anyone experienced anything similar or have any ideas/suggestions, please? Sorry for the length of the post?
