 Hyundai-Forums.com > Hyundai Models > Accent Forum > 3G (2006+) Accent > Accent 3G Document Library
Closed TopicStart new topic
> Engine Damper Mod
Komptek
post Jul 14 2008, 03:23 PM
AMSOIL T1 Direct Dealer
Drives: '07 Accent SR, '09 Kawasaki Concours 14 ABS
OK here it is. The Engine Damper from KFXperformance. I'd rate this add-on a must have 8 out of 10, the install was on a 2007 Accent SR. It has the DCsports Strut bar and AC. Some modification is needed.
1. You will need a longer screw and washer to mount the front bracket.
2. You'll need to cut out a section fo the DCsport strutbar.
This post has been edited by Komptek: Jul 14 2008, 03:25 PM
Attached File(s)
LilBean
post Jul 22 2008, 08:14 PM
Expert
Drives: 2010 Nordschleife Gray Genesis Coupe 3.8 Track
relevance
QUOTE(ewing @ Jul 21 2008, 03:07 PM)
i don't accelerate quickly or shift hard and all that that would make the engine really move harshly.
BUT, i do drive down a couple of REALLY rutty gravel/dirt roads. if you drive them slowly, it's a real bone shaker. i tend to drive them quickly (60kmh) in order not to allow the suspension to let the wheels dip down into the ruts - just cruise over them w/ less jarring, but it still vibrates.
would this mod be of much use driving on areas like this? ie will it save motor mounts/suspension/other bits from some wear? enough to make it worth the price of admission?
the road is a bit over 4km long and i plan to drive it both ways 1-2 times/week until about october.
if it'll do wonders, then i may be able to justify the expense. if not, fuggedaboutit!
[right][snapback]177701[/snapback][/right]
The engine damper has nothing at all to do with road conditions (bumps, ruts, etc). or the vehicle's suspension. The engine damper prevents or reduces the engine's "torquing" effect under hard acceleration. Instead it tranfers that torque to the wheels rather than allowing the engine to "twist" in the mounts, so to speak.
So to answer your question, no it will not "save" your engine mounts on rough roads. Your engine mounts have nothing to do with rough roads, the car's suspension does. Engine mounts dampen the vibrations produced by the engine so that they are not transferred to the body of the car. If you've never driven a car with a bad engine mount, trust me, they make a HUGE difference.
No New Posts Engine Swap 1.5 I4 To 2.7 V6
engine swap
3 wanz 611 16th March 2010 - 03:32 AM
Last post by: Rob Smith
No New Posts Engine Tick
6 morenar 285 15th March 2010 - 03:12 PM
Last post by: JWMathews
No New Posts Engine Light On
2001 Hyunda Accent GSI (automatic)
4 dleigh 73 13th March 2010 - 05:17 PM
Last post by: jsinton
No New Posts Moderator Knowledge
7 Normbo 65 13th March 2010 - 04:50 PM
Last post by: lovemysantafe
No New Posts Engine Problems
New engine fitted, won't start!
1 fakeceleb 58 13th March 2010 - 10:38 AM
Last post by: Mr Pogle
19th March 2010 - 10:05 AM
Privacy Statement
