 Hyundai-Forums.com > Hyundai Models > Tiburon Forum > GK Tiburon (2003-2008)
> Turnsignal Issue+possible Neutral Switch Problem
sDUbay
post Jul 8 2008, 01:11 PM
Drives: Tibuton GTV6 2004
Hello all
i'm having 2 issues with my Tiburon GTV6 2004
1. the turn signal stays on, I've read that this is caused by a mis working relay the NEC-EP2-3N1ST which I ordered already and will install. The only difference I get from the other posts on this issue is that sometimes i can make the turn signal work. It takes some switching but lets say 1 time every 10 i tun the left signal on it starts working pretty much right, the times are maybe a bit off but i can at least turn it off at night.
other users said that they had to unplug the fuse to turn it off, could this mean that my issue isn't caused by the NEC-EP2-3N1ST???
2. I think i have to replace the Neutral Safety Switch. I have manual transmission but sometimes when i have to start the car turns on but the starter doesnt run nor sparks, could please anyone confirm that the issue is caused by the Netural Safety Switch or something else, is this the right piece:
AIRTEX Part # 1S5750
http://www.rockauto.com/catalog/raframecat...c1425697k929826
Thank You!!
S :57:
LilBean
post Jul 8 2008, 01:56 PM
Expert
You might also want to think about the BCM being bad... it's a common problem in this generation Tiburon, and one of the surest signs is turn signal problems. Is it out of warranty? If it is out of warranty that's bad news, as the BCM is anywhere from $500 to $1000.
Hopefully your simple fixes will be the only problem and will take care of it.
sDUbay
post Jul 8 2008, 05:44 PM
you think the ignition issue could be somehow connected with the BCM? I thought it could depend only on the Neutral safety switch..
the fixes i was talking about was posted here
===> LINK
http://www.newtiburon.com/hosted/diy/bcm/D...om%20Forums.pdf
maybe anybody needs it :) it's about replacing a relay in the circuitry
Vic
post Jul 20 2008, 01:20 AM
Drives: 2003 Tiburon 2.0
I had the same problem with my right turn signal. Sometimes it worked after some switching but it was a big pia.
Did the DIY at http://www.newtiburon.com/forums/showthread.php?t=102241
A year later and it still works!
sDUbay
post Jul 20 2008, 09:37 PM
YYYEEEAAAAAHHHHH :right:
it worked!!!
Holy crap it was hard to rip out that relay but it worked tht the important
the DIY is awesome!
the clips on the bottom of the DCM are almost impossible to put back in place think i'm going to use dutch tape opn it
but yeah :w00t: 600 to 1000 $ savings on my account
:banana:
4 Osaka 186 17th November 2008 - 09:24 PM
Last post by: mrstats
No New Posts Problem Starting
H-1 tourismo
0 ricky1947 17 8th November 2008 - 12:45 PM
Last post by: ricky1947
No New Posts Problem (?) With 09 Sonata
Gas Pedal
18 sbi 372 29th October 2008 - 12:46 AM
Last post by: MiamiLX
No New Posts Switch To Synth
1 spaceship 105 21st October 2008 - 11:02 AM
Last post by: RetsaM
No New Posts Topic has attachmentsProblem With Pump.
2 Maquinista 184 13th October 2008 - 09:07 AM
Last post by: Antares
22nd November 2008 - 04:04 PM
