But also the subs have to be 2 ohm as well most single coil are four ohms. Now the amps make sure as qouted below the amps are 2 or ohm stable or you will mess up a sub or amp. Now basics from what I remember If U have 2 4ohm subs 4ohms and 4ohms = 2ohms. Now If you want to use both amps single coil subs make the wiring limited. You may just want to leave you set up like you have it. If not matbe a little more info would help us :beer:
QUOTE(caballoballo @ Jul 23 2008, 07:28 AM)
If the speakers are 4 ohms single coil then you only have to tie both positive, then tie both negatives for both speakers, that way you get a 2 ohms configuration. Now, you need to make sure your amp can take a 2 ohms load, if not, the amp will go into protection. 2 omhs stereo is not the same as 2 ohms mono. There is a web page named basic car audio, there you have all the info you need.
[right][snapback]178101[/snapback][/right]
