Dear bedver,
If the filter does not help your problem, your heater box may be retaining water. The drain from the heater box(which also holds the A/C chill core) is easily clogged with mold and algae. You can tell if your drain is working by just checking for a puddle under your Santa Fe with the A/C running...you should get a steady drip .
If no drip, try reaming the drain hose to clear out the clog. In the US, we use a piece of straight coat hanger wire and run this in and out of the drain hose until all of the mold flows out.
Byron
