Dear vdoe , et al.,
Please remember that this is a 4 cylinder, 4 stroke engine Double Overhead Cam engine with 16 valves....8 intake, 8 exhaust.
With the camshafts PROPERLY installed and torqued down, you will always have
1) one cylinder on the intake stroke ( intake valves open) 2) one cylinder on the exhaust stroke (exhaust valves open) 3) one cylinder on compression stroke ( intake and exhaust valves closed) 4) one cylinder on power stroke (intake and exhaust valves closed)
or you could be partly between strokes and have intake valves opening and exhaust valves closing. Also remember that the Hyundai OEM 2.4 liter valve duration is I think 256 degrees. So you will have some overlap of intake valves opening while exhaust valves are closing at TDC of the intake stroke.
Byron
