My needs a few items to get it into order. The check engine light came on and threw a DTC code P0350 - "Ignition coil primary/secondary circuit malfunction."
It looks like there are three coils, each driving two cylinders. I do not get DTC codes indicating misfires on any cyls. If I did I suppose I could just swap coils around to ID the bad one.
Any hints on where to start with this one? The engine is running a little rough, but only to the degree that I would think maybe one or two cyls was missing.
Thanks,
